why do i keep blowing fuses...
Old Apr 28, 2003 | 10:36 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
the fuse that powers my windows,locks,inerior lights,etc.... blows every time i plug in the cigarette lighter
what could be wrong?
Old Apr 28, 2003 | 10:47 PM
Dirty Rob's Avatar
Your lighter is shorting out and blowing the accessories fuse. Could be a bad wire, could just be the **** that builds up in car lighters. Pull that thing out, make sure the wires are in good shape, and if you so desire, put another one in.
Old Apr 29, 2003 | 07:51 AM
Deemax's Avatar
Car: '89 RS Convertible
Engine: 355
Your lighter's bad. But then...ya oughtta quit smoking anyway
Old Apr 29, 2003 | 10:52 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
no, smoking isnt my thing.....actually i wont let ANYONE smoke in my car...
i use it for the interior neons and recharging my cellphone
i'll check the wires and clean it up....thanks for the advice
Old May 1, 2003 | 11:01 PM
Tyler-88's Avatar
mine popped the fuse when i plugged in the cig lighter as well. works 100% when i just it to charge my phone though. ive also herd that its becuase ther is ish built up inside the female end of the cig lighter.
Old May 2, 2003 | 12:50 PM
Camaro90RS43's Avatar
Hey i'm sorta having the same problem except nothing is plugged in my cig lighter but everytime i put the fuse in it'll work for like a second, but once i start the car the fuse blows. And if i do plug the cig lighter in the fuse just blows everytime i put it in, do u guys know what's going on? Thanks.
Old May 3, 2003 | 12:50 AM
Dirty Rob's Avatar
Disconnect the cigarette lighter, make sure the wires are clean, not stripped or worn out and not touching anywhere. Put a new fuse in, see if it blows. If not, you found your problem.
Old May 3, 2003 | 10:37 AM
thanks i'll try that today.
blackz281le
Jan 11, 2016 07:51 AM
Fanatic1074
Oct 2, 2015 03:47 PM
86IROC112
Sep 28, 2015 08:17 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
90formulaVortec
Sep 3, 2015 09:26 AM
