Fog light addon
Old May 1, 2003 | 10:09 PM
91FirebirdFmla's Avatar
Car: Green 1991 Firebird Formula
Fog light addon
I took off my switch panel and saw that my car was wired with the harness for a foglight switch. Does anyone know what else I need to install, aside from the foglights themselves to make the factory wiring for the foglights fully oprational, even for a pair of aftermarket foglights?
Thanks.
Old May 3, 2003 | 08:02 AM
dsaint1347's Avatar
TTT
I would also like to know the answer.
Old May 5, 2003 | 07:37 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Get the fog light switch and put the relay in. Then find the harness up where the foglights are and hook it up.
Matt
Old May 5, 2003 | 08:31 PM
where is the harness for the relay located?
Old May 5, 2003 | 08:33 PM
Matto'85TA's Avatar
On my '85 TA its near the fuel pump relay by the driverside firewall. It may be where your headlight control module is. Though it may have been moved around
Matt
Old May 5, 2003 | 08:39 PM
Matto'85TA's Avatar
OOPS. Just read that teh relay is located under the dash somewhere. Apparently it got moved there during the years. Juse look for loose conectors tied off somewhere.
Matt
Old May 5, 2003 | 11:47 PM
is the underdash location applicable for the '91 cars? I did a board search and everything else I read pointed to the firewall and the inside of the front left fender. The only specific year mentioned was '92. I haven't looked yet either though. I need daylight for that. At least I know where to start.
Thanks for your help
Old May 6, 2003 | 06:20 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It should be on the driver side mounted all by itself near the fender area. It is typically smaller than most of the other relays.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
