brights and fogs at same time
Old May 5, 2003 | 08:46 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
How do you make it so the brights and fogs run at the same time? I searched but couldnt find it, I know this has come up before. I thought you cut and grounded a wire, but which one? Or is there a different way? I have a '85 TA with the stock fogs replaced with driving lights. I'm gonna do a lot of night driving up north this summer so I want the most light possible.
Matt
Old May 6, 2003 | 12:59 AM
Tyler-88's Avatar
say your fog lights are wired to your low beams. if your switch is ran to your low beam wire, cant you just connect that same switch wire to the high beam circuit as well? but than again the wire harness isnt built for major wattage. i had to rebuild mine and use a relay and a circuit breaker to get the high beams to work correctly. (460watts)
Old May 6, 2003 | 10:40 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Rewire the fog light relay so that it is always on with the parking lamps are on. This removes the high/low beams from the equation completely.
Old May 6, 2003 | 07:23 PM
Matto'85TA's Avatar
I was considering both ideas:
I would wire them directly to parking lights, but I dont want them on all the time( like when I'm in the city).
I also dont want to fry my harness, I have enough problems with it.
I thought I heard there was a wire I had to cut and ground but I'm not sure.
Matt
Old May 6, 2003 | 09:53 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
https://www.thirdgen.org/techbb2/sho...+or+for+lights
Old May 7, 2003 | 02:09 PM
Matto'85TA's Avatar
deadbird: Thanks alot. I'm a bit confused though. Which end of the wire do I ground. The one still attached to the relay or the one that isnt?
Matt
Old May 7, 2003 | 07:40 PM
deadbird's Avatar
Engine: TPI 305/ v6
Matt, depending on which wiring setup you have (according to the diagrams), for both, when you cut the light green wire, you need to tape off the one going into the relay (or from the light switch). The other (on the relay) gets grounded. Either way it's wiried, as long as the lt grn wire on the relay is grounded, the fogs will stay on.
Old May 7, 2003 | 07:48 PM
Matto'85TA's Avatar
Thanks. So when the brights turn on the ground is removed. I get it now.
Matt
Old Jun 19, 2003 | 05:09 PM
Flyersman29's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
sometimes when i hit the high beams.... the fogs will stay on...
z28_AJ
Aug 27, 2015 08:59 PM
TheExaminer
Aug 26, 2015 04:59 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Omega
Aug 10, 2015 10:24 PM
