Lights go off when i hit brights
Old May 20, 2003 | 02:14 AM
350 TPI's Avatar
This started about a week ago.It works fine on low beam but when i hit high beams they go out and just the fogs stay on.Do i need to replace the whole turn signal switch?I VERY seriously doubt both high beams burned out at the exact same time.Thanks,chris.
Old May 20, 2003 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Shortly after I bought my car, I was driving at night. I hit the high beams only to see blackness--scared the hell out of me! The problem is probably the high beam/low beam switch (stupidly, I can't think of the correct name at the moment), located on the steering column under the kick panel. It's a pain to replace because of location. I dropped my steering column a bit, which provided more room to work.
JamesC
Old May 22, 2003 | 07:47 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
It's the Dimmer Switch... it's on the steering column by your feet and has a metal rod that comes down from the wiper/turnsignal switch to activate the brights. Napa $15 and a PAIN IN THE **** to get to the 2 bolts.... you have to adjust it right also.
Orr89RocZ
Feb 13, 2016 10:04 PM
db057
Sep 4, 2015 07:57 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Omega
Aug 10, 2015 12:46 PM
