Nothing works
Old May 24, 2003 | 11:21 AM
Fastcamaro's Avatar
Nothing works
I was trying to hook up my deck and now nothing works... I mean i have no head lights, no power to the deck no interior lights, or dash lights.. Please help!!
Old May 24, 2003 | 02:57 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Check all the fuses. Make sure your battery didnt discharge. Does any electrical component work? Does the car start? The fusible links may have blown.
Matt
Old May 25, 2003 | 01:19 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Make sure you didn;t cross-thread the battery when you hooked it back up. I had the same problem when i installed my deck and it was all because I very slightly cross-threaded the battery and the connection wasn;t right.
Old May 25, 2003 | 09:01 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: 700 R4
What works
My car starts and runs good. the defroster works, the heat and the ac. what do you mean the battery cables are crossed?
Old May 25, 2003 | 09:02 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
Fuses
O ya and all my fuses are good!
Old May 25, 2003 | 11:02 PM
EYEROCK89's Avatar
Car: 1989 IROC
Cross-threaded...not crossed wires. I'm assuming you disconected either the positive or negative ground wire while you were doing the work on your car. Anyway, make sure that when you screwed the battery cable back in that you did not cross-thread the battery cable bolt. Lol, if you would have crossed the wires, there would have been a firework show to let you know you did somehting wrong.
Old May 26, 2003 | 09:19 AM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
its not !!
Not to be stupid but i still really don't know what you are saying about the battery? If it was something with the battery the car wouldn't even start right? The car dose start and some of the electronics work, like the rear deck lid and the defroster.
Old May 27, 2003 | 12:10 AM
EYEROCK89's Avatar
Car: 1989 IROC
No, not nessecarily. When, my positve battrery cable was cross-threaded, the car would start fine, but my headlights, interior lights, pw, pdl, and rear hatch would not function.
Old May 27, 2003 | 08:35 AM
Fastcamaro's Avatar
So what did you do to fix it??? O ya and my deck lid dose work! I was told it might be a fusable link! What is that and were is it?
Old May 27, 2003 | 01:34 PM
EYEROCK89's Avatar
Car: 1989 IROC
Well, as long as it;s not cross-threaded really bad which it shouldn't, just unscrew it and re-thread it the right way. It could be a fuseable link or it could be the headlight switch mechanism. Lets hope thats not what it is. When I get home from work, I'll scan the wiring diagram for the headlights and send it to you. It will pinpoint the fuseable links and other componants so you have a place to start looking.
Old May 28, 2003 | 08:37 AM
Fastcamaro's Avatar
I don't think it has anything to do with the battery because it is new and i remember installing it correct, but i guess it wouldn't hurt to check. That would be great if you could tell me where the fusable links are!!
Old May 28, 2003 | 09:14 AM
EYEROCK89's Avatar
Car: 1989 IROC
Yeah, I didn;t figure it was the battery. I was just trying to give you the easiest and cheapest thing to look at.
Old May 30, 2003 | 08:54 AM
Fastcamaro's Avatar
Were are the fusable link for the headlights in my car?
Old May 31, 2003 | 03:07 PM
Odyssey's Avatar
That's impossible
Old May 31, 2003 | 06:25 PM
EYEROCK89's Avatar
Car: 1989 IROC
Odessey - Yeah, except that it's not.
Old Jun 3, 2003 | 05:52 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
I think i know whaat happened!! I had my battery cable wrong and i think it messed up my battery. Anyway i triedto jump it but when ever i tryed to start it it smoked from what looked like the starter. I have one question what are those red wires comeing of of the starter are they the fuseable links because i think i fried them?
Old Jun 3, 2003 | 08:27 PM
Odyssey's Avatar
Nah I just think only a moron could believe that's true A cross threaded bolt still has VERY good contact with the battery post. Plus if your starter was turning, which is THE biggest current consumer in your car (unless you have a high wattage amp), then we can DEFINITELY rule out the cross threaded bolt as the cause of your other accesories not working!!
Old Jun 4, 2003 | 06:05 AM
EYEROCK89's Avatar
Car: 1989 IROC
Odessey - Seriously, get a life. It happened, get over it. I was just trying to give the man a quick place to look first. He ruled it out, so lets move on.
Fastcam - Anytime you possibly overloaded the battery, it;s not a good thing. If you fried the wires, you need to replace them and then do some current checks at those points to make sure you're not overloading them again. I overloaded my battery and fried the ignition to alternator wire and caused all sorts of problems. Anyways, get thos wries fixed then start looking elsewhere if that doesn;t do the trick.
Old Jun 4, 2003 | 08:51 AM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
If the fuseable links are dead, how do i test them to make sure what ones are dead? I sure that they are shot because ofthe smoke! O and a friend sayed that he just bypassed his and didn't use them. Would that mess up the car?? Should i just do that?
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
