criuse control and lock up dont work?
Old Jun 2, 2003 | 11:11 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
for some reason ever since i bought the car the cruise control and the lockuo converter wont work anyone have any ideas someone told me they are connected somewhare?
Old Jun 3, 2003 | 04:13 AM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
What year car do you have? Could be your VSS Buffer box because it sends the signal to you computer for the Lock-up of your converter and also it sends signal to your cruise control.....Just an idea maybe someone else has something to say about it....
Old Jun 3, 2003 | 06:08 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: criuse control and lock up dont work?
Does the speedo work? Tg's used a mechanical and electronic speedo's. With a mechanical cable driven speedo the cable drives the speedo as well as a little Hall generator in the speedo head. Pulses are sent to the VSS buffer module from the Hall unit and then to the ECM for control of TCC, EGR and cruise. Electronic speedo's are basically the same, however at the trans there is a Hall unit in place of the cable drive assy and the pulses are sent to the VSS buffer for the electronic speedo, TCC, EGR and cruise. Normally without a VSS signal the SES light will come on after about 10 min of driving over 35 mph or so.
Old Jun 3, 2003 | 08:19 AM
1987gt's Avatar
Car: 1989 GTA
speedo works but the tach only works up to 3000rpm wont go any further and i have a 1989gta.whare is this box your talking about could you tell more and how to fix it?
Old Jun 3, 2003 | 08:50 AM
Car: 85 Z
Engine: 383
It would be on the Passengers side by the computer Here is a pick of it.......
Old Jun 3, 2003 | 08:55 AM
Car: 85 Z
Engine: 383
I beleave that your buffer should be the same part number as the one in the pick if so you can get one out of a junk yard from a mid 80's olds Delta 88 for shure don't know about any other models but that is the one I use for my 91 gauge cluster and it works great.
The green wire is 4000ppm that lead goes to you speedo the red wire goes to you cruise the brown goes to you computer for the lock-up and other things both red and brown are 2000ppm
Old Jun 3, 2003 | 09:26 AM
1987gt's Avatar
Car: 1989 GTA
i know what your talking about i have taking the computer out a couple of times i put a new one in i saw that piece do you think thaat will fix my problem? noone has ever even told me about that go figure lol.oh yeah if i find one it has to be the same part# right? and it will just plug right in right?
Old Jun 3, 2003 | 10:07 AM
Guest
Guest
Posts: n/a
if it was the VSS butter (also called the 4 out buffer) your speedo wouldn't be workign as well
Old Jun 3, 2003 | 11:02 AM
1987gt's Avatar
Car: 1989 GTA
well so much for that idea i was getting all happy thinking maybe that was it son of a b.well any other ideas?
Old Jun 3, 2003 | 05:31 PM
Car: 85 Z
Engine: 383
Well the resister could be out for the 2000ppm.....It is very cheap to get one I think it is worth a shot.....
Old Jun 3, 2003 | 05:55 PM
patrickm00's Avatar
while it does seem unlikely, one of the buffer outputs could have failed. the junkyards will probably just about give them away given the number of people that actually buy them, and it's only 5 minutes worth of work to try, so i say go for it.
(also, your 89 will have an electonically driven speedometer)
Old Jun 3, 2003 | 05:56 PM
patrickm00's Avatar
and while you have things apart check the wires for continuity
Old Jun 3, 2003 | 10:11 PM
1987gt's Avatar
Car: 1989 GTA
i want to thank everyone for the help i appreciate it.i will try the buffer maybe i will get lucky who knows. its my tach that doesnt work not the speedo o and what is a 2000ppm? resistor?
Old Jun 4, 2003 | 03:57 AM
Car: 85 Z
Engine: 383
pulse per Mile
Old Jun 4, 2003 | 09:11 AM
1987gt's Avatar
Car: 1989 GTA
chris what is the 2000ppm and how do i fix it or replace it?
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
The_Phoenix
Feb 4, 2016 07:10 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
