Extending Fusable Links and other wires
Old Jun 18, 2003 | 12:31 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
Ive got a 92 gta with the 350.. right now Im switching to super ram and im looking at ways to get all the wires running under the base lid cause its a pain in the *** getting the valve covers off and on with that loom right in the way with bigger roller rockers/tall covers...
so far i have the injector wires tucked in pretty good, talk about a pain in the *** gettin those in there... then the IAC, coolant, and TpS switches are up where they should be.. dumped the AIR pump so i just tucked the two connectors by the EGR that is also disconnected.
now the trouble spots
1. on the driver side the alternator connector is a little too short.. looks like a 12 gauge red and 16 gauge red, shoudlnt be any problems extending them right?
2. on the passenger side i have two sets of wires left, one is the two connectors for Air Conditioning, starts out with three wires but i plan on splicing it where it branches into four cause its a little easier to manage, again looks like normal 18-20 gauge wire, pretty thin stuff..
3. now the one that im really questioning.. is the branch of wires that comes off of the starter... there are 4 red 12 gauge and two or three 18 gauge wires (knock sensor/temp sensor/solinoid?)
is it ok to extend these 12 gauge wires with just normal wire dont have to use any special fusable links or anything?
i plan on soldering and heat shrink sealing all the connections and wrapping them in some kinda loom as to avoid grounding out and what not under the plenum
:hail:
any help to keep my car from burning down would be greatly appreciated
Old Jun 20, 2003 | 12:39 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
1) No problems extening them.
2) Sure
3) No problems extending but, try to keep the solder point about a foot away from the fusible links to keep from melting them down.
Hellbillydeluxe
Sep 22, 2015 09:58 PM
theshackle
Aug 23, 2015 03:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
overdriv
Aug 20, 2015 03:52 PM
