wire colors
Old Jun 19, 2003 | 11:40 AM
demonchild's Avatar
wire colors
does anyone have a list of all the wires, their color, and what they go to for an 86 transam dash?
Old Jun 19, 2003 | 12:23 PM
demonchild's Avatar
let me rephrase:
i am swapping a 6 cyl mechanical cluster for an 8 cyl electric speedo and cluster. there is two connectors that plug into the cluster. the 6 cyl and 8 are not the same. what needs to be changed. what plugs do the grounds run to. what plugs do the rpm, oil pressure, water temp, and gas guage run to?
any help is appreciated.
Old Jun 20, 2003 | 10:43 AM
demonchild's Avatar
cmon someone has to know what color the oil pressure sending unit, gas gauge, water temp, and voltage wire colors are on a v6 wiring harness! please help or lead me to something that can help me. ill scan the wiring diagrams out of the chiltons if anyone can read them...
Old Jun 20, 2003 | 12:53 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
GM shop manual from www.helminc.com will list all the colors and connector pins you need.
Old Jun 20, 2003 | 01:06 PM
demonchild's Avatar
wow there is a G0D
Old Jun 20, 2003 | 01:12 PM
demonchild's Avatar
but they dont sell wiring diagrams.
it says the wiring diagrams were sold seperate from the shop manual
Old Jun 20, 2003 | 11:33 PM
LI Tommy's Avatar
OK I just got done with a very similar swap (mine was a dummy light cluster for a gauge cluster). The easiest way that I though of to do this, after I was done of course, is to take your old cluster and trace where a wire goes on the cluster. Note what the wire controls and what color that wire is. After you did this look at the new cluster and trace back, say the oil pressure gauge, and move the wire to the correct position on the connector. I hope this makes sense.
Also when I was done there was one extra illumination wire which I just taped to make sure that it did not ground out and stuffed it behind the dash. The gauges still light up nice and bright.
One more thing, If the cluster you are swapping from has dummy lights instead of gauges you will need a new temp and oil senders. You will also need to run a wire to the distributor for the tach.
If you need any help feel free to ask.
Old Jun 20, 2003 | 11:35 PM
LI Tommy's Avatar
One more thing and I'll stop.
When removing a wire from that connector you want to push the wire further into that connector and put a small flat object, like a jewelers screwdriver, in and then pull the wire out. You will see why after you get the first one out.
Old Jun 21, 2003 | 02:47 PM
demonchild's Avatar
that was th e origional plan, but the person that had the car before me hacked everything up. i am swapping because nothing works right. all the wires were already dosconnected and messed up.
i am really glad that was able to work for you...im probably going to take the car to a auto electician and let them mess with it.
have fun with your new cluster because mines turning out to be a cluster f***.
Linson
Aug 21, 2015 02:12 PM
LT1Formula
Aug 20, 2015 09:36 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
87350gtanj
Aug 8, 2015 10:32 AM
