Help, smoke is coming out of the buttons!!!!
Old Jun 26, 2003 | 07:56 AM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
OK, i was driving to work this morn and noticed small wiffs of white smoke coming out of the dash panel where the fog light,defrost, and trunk switch are.
It wasn't pouring out or anything but occasionally would come out. It started when i turned the fan dial for the ac.
I haven't had time to pull it apart as this happened on my way to work and i don't have the hex bit i would need to get it off.
Does this sound like a frayed wire or am i going to be running new wires throu the whole car???
Old Jun 26, 2003 | 08:15 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
thats kinda wierd......beter get that fixed or you'll look like Cheech and Chong in "Up in Smoke" when they are smoking the joint in the car......lol sorry haha
Old Jun 26, 2003 | 09:46 AM
Car: 1987 Trans Am
Engine: tree-fiddy
ok, i think i figured it out, there was prob a different radio in the car and when they put the original back in they did a rush job and didn't get all the wires wrapped. cause i just noticed the plate around the radio is loose.
I'm gonna take it apart this weekend and find out for sure thou. wish me luck.
Hope fully it'll make it home and not explode in a shower of sparks. <knock on wood>
Old Jun 26, 2003 | 11:16 AM
Car: 1987 Trans Am
Engine: tree-fiddy
ok, i pulled it apart on my break and it's coming from the AC controls. There's some kind servo or relay(round, looks to be where the AC control arms connect)
So i guess i'll be hitting the junk yard saturday.
Old Jun 28, 2003 | 06:34 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
better make sure there isnt wire problme tot he blower motor or to a/c under hood that would be causing the burnt up controls panel, or...
good luck
Old Jun 28, 2003 | 08:14 PM
Car: 1987 Trans Am
Engine: tree-fiddy
ok, replaced the a/c control and it seems to be ok. I pulled apart the old one and the copper contacts inside were corroded bad, I think it just wore out.
Red iroc-z 305
Sep 30, 2015 05:22 PM
5spdcamaro
Aug 28, 2015 02:12 AM
smooth
Aug 18, 2015 06:34 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
