Power antenna wiring
Old Jun 27, 2003 | 02:33 PM
JayHodge's Avatar
Car: 1987 Iroc-z
Engine: 5.7L 350
Transmission: 700 r4
I have a gray green and white wire running to my power antenna on the right side.....the gray one runs into where the cd player is and the other 2 idk what they do....n e ideas....the wires on my new power antenna are red and blue how do i wire this??? the manual says the red is the hot wire and hte blue is hte switch wire that goes to the cd palyer where do i hook it into thx
87 iroc 350 tpi
jay
Old Jun 30, 2003 | 05:27 PM
cfabe's Avatar
stock setup, three wires, one is trigger from the radio, one is power, one is ground.
Get a voltmeter or a test light and check for which has power on it, thats the wire to use for your new antena's power. The new antenna probably wants to get its ground from the body where it mounts, this should be okay but if it's not working you may need to tuck a ground wire in there someplace to give it ground.
Old Jul 1, 2003 | 06:57 AM
BirdCrazy's Avatar
The way I had to replace mine was run the new red wire complete like the instructions say. I tried splicing the new red wire into the old and I got nothing. So I pulled the old ones and ran the new red wire to the fuse block where the old wire had been. I can't remember what I did with the blue wire that one may have worked just by splicing.
Vintageracer
Jan 10, 2020 05:33 PM
Bert87
Aug 23, 2015 03:50 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
