where are the 2 power window wires?
Old Jun 28, 2003 | 11:54 AM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
I found one of them but i cannot find the other. Do they both look the same? Where do they come from?under carpet maybe?
Old Jun 29, 2003 | 12:43 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
thru the door frame betwwen the hinges there is a rubber boot.They run em in there,then to the fuse box & a relay probably.
Old Jun 29, 2003 | 11:22 AM
Car: 84 Z28
Engine: 355c.i.
thanks i found them, the pasanger side motor is shot hehe
Old Jul 16, 2003 | 01:45 PM
Tyler-88's Avatar
where does the harness plug into the fuse block? i cant seem to figure it out :\
Old Jul 16, 2003 | 01:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I beleive it goes to the fuse block & uses a relay
Old Jul 16, 2003 | 02:08 PM
Tyler-88's Avatar
where abouts at the fuse block. does it plug in up above or what. should it just clip in or do i need more connectors. right now on the harness i have a 4 plug - female clip with 3 wires in it. i dont see a spot for it to go pictures would be nice
Old Jul 16, 2003 | 03:00 PM
Tyler-88's Avatar
bleh, i have a 90-92 harness - wont work with my 88
Old Jul 17, 2003 | 03:17 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
heres a pic from a spare fuse block out of an 84z28.the relays/circut breakers go where my finger is pionting,this is the side closest to steering column.the relays have a bare metal cover & are larger than fuses.sockets also are different from the fuse sockets.theres 2 one for i think the one above finger is for the windows.the one in front of finger i forget whats it for.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
