Turn signal light staying on?
Old Jul 4, 2003 | 09:18 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
This just started happening recently. My left turn signal light is staying on when the lights are on in my dash. However, the light is not lit on the outside of the car. What the heck would cause something like that?
Old Jul 4, 2003 | 10:10 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
check the bulbs. sometimes a burnt out bulb will make that happen.
Old Jul 4, 2003 | 10:17 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
I will bet you that the headlight switch is shot. If you are not using the turn signal, and the light is on just on the dash, then change the headlight switch! The exact same thing happened to me.
Old Jul 4, 2003 | 10:29 AM
Sonar_un's Avatar
Car: '86 T/A
I checked and my driver side front turn signal bulb is out...
That has to be it... thanks!
Fronzizzle
Mar 18, 2019 08:29 PM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
