What's this fuse next to the fan relays?
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Anybody tell me what this is for? Is it the ECM power? There's one red and one orange wire going to it, and it looks like it's supposed to have a weatherproof cap, but it's gone.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
To add to that, if you have it, it's also power to the MAF power and burnoff relays plus, it's also the main/constant power to the ECM.
Car: 1989 IROC-Z
Engine: L98 350
Are you serious??? I've been screwing with a code 36 for the longest damn time. If that fuse holder was corroded and not allowing all current to go through, might it be responsible for that code??? I replaced EVERYTHING except for the ECM! Might this be it???
Engine: TPI 305/ v6
Believe it or not, I'm serious.
Honestly, if the power/connection at the fuse is bad, you'd have more problems than just a code 36.
Code 36 relates to the MAF burnoff circuit. This can be anything from the MAF burnoff relay being bad (which I've seen being a problem more than once on here) to a problem in the circuit supplying the power to it (the relay).
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
But here is the catch...if that fuse is not allowing power to go past it, the car will not start!
gta892000
Sep 16, 2015 12:37 AM
