Possible to check Head light sensor.
Old Sep 10, 2003 | 08:12 PM
hrddrv's Avatar
Car: 86 TA
Engine: 305 Carbed. Mainly stock Not running
Transmission: stock
I know one or possibley all of my sensors are bad. The lights do not go up. Corrections the drivers light does not go up and the passenger light goes up sometimes when I play with the switch. I have replaced the switch with a brand new one to check to see if that was the problem and it was not, so I know it is a sensor. Is there a way to check which sensor is bad? I do I just need to replace them all or one at a time to see which one is bad?
Old Sep 11, 2003 | 09:30 PM
hrddrv's Avatar
Car: 86 TA
Transmission: stock
So no one can help or give me any advice? I know I do not come here often but I figured someone may know. Any help would be appreciated.
Old Sep 12, 2003 | 10:21 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
i never knew there was a sensor, it might be the relays for the headlight motor, i think they are called headlight isolation relays, or it could be the motor themselves the gears in them will powder over time
Old Sep 13, 2003 | 09:29 PM
hrddrv's Avatar
Car: 86 TA
Transmission: stock
Sorry I meant relays. I consider them the same thing. I just want to know if there is a way to test to see which one or if all of them are bad. Thanks.
Wade787b
Sep 29, 2015 01:15 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
