do i have a chip ?
Old Sep 14, 2003 | 10:55 AM
white91formula's Avatar
Car: 91 formula
Transmission: t5
do i have a chip ?
when i bought the car, i was told that it has a chip in it, how can i find out if i do or not cuz i am doubting that it does, where would i be able to look to find out ?
new at the fbody's so all the help i can get is appreciated
Keith
Old Sep 14, 2003 | 06:55 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Welcome, the "chip" or PROM is located under a lid or cover on the ECM. Generally aftermarket PROM's will be appropriately labeled. The ECM is located under the dash on the passenger side. The PROM IC is held in with what they call a carrier, it locks in on either end and the whole thing comes out as one piece including the carrier. Otherwise it looks like any standard PROM cause that's what it really is, just programmed for the particular vehicle. They do this so they don't need many different ECM's for all the different models. The PROM contains what they call the "personality" of the car. If you remove the ECM always disconnect the battery first, and when handling the PROM touch one hand to something metal on the car to discharge any built up static electricity in you body. They have wrist straps for that purpose, but for most average situations just grounding yourself before handling the PROM should be fine.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
