distributer problem
Old Sep 15, 2003 | 07:40 PM
m300slr's Avatar
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
distributer problem
I was just looking at my distributor cap and I noticed that the bolt that holds the distributer in place was realy loose. I found this out because I turned the distributer(darn). Anyway, I timed it a 6 deg like the sticker in the hood says, when I drove it it had no power at all, so I compensated to 12 deg, but I know thats wrong and I dont want to run it like that. I guess there is some sort of tan with a black stripe wire that I am suposed to disconnect, but I cant find it(or so says the sticker under the hood). If someone can help, I would appriciate it.
Old Sep 16, 2003 | 04:29 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
The wire is by the firewall, passenger side. There are wires running along the top and the wire you're talking about comes out to a straight plug then goes back in.
Old Sep 15, 2013 | 10:39 PM
Biggd4355's Avatar
Re: distributer problem
I have advanced my timing and never had a problem, until the starter kicks back. Then I just retard it a little.
Old Sep 15, 2013 | 10:41 PM
Biggd4355's Avatar
Don't try changing the timing with the engine running, the ecm will compensate. Do it with the engine off.
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
