F Lamp sensor lacation for digi dash
Old Sep 18, 2003 | 03:09 PM
Chet's Avatar
Car: GTA
Anyone know exactly where the two lamp sensors are for the digital dash D.I.C?
Old Sep 29, 2006 | 06:48 AM
jdspool's Avatar
I've asked this same question on 3 sites and got no answer! C'mon folks! I get an "F Lamp" and R Lamp" on my screen -- but all lights work just fine! Without ripping the car apart -- there's gotta be an easy way to LOCATE the sensors that trip the faults. Help!
Old Sep 29, 2006 | 03:55 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
i found mine to be very sensitive.when i replace a blown bulb i have to replace pairs at the same time.otherwise it tells me i've still got a bulb out.presumabley because the current draw and voltage drop are different on either new or different brands.don't know if that's why your asking or not.
Old Sep 29, 2006 | 04:03 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
gah.. i have the same thing. every freaking bulb on my car is new save for the headlights (which both work) and i still get "f lamp" intermitantly. i just want it to say "ok pontiac system" like it used to do.
Old Sep 29, 2006 | 06:04 PM
rhomanski's Avatar
you'll have to replace both headlights at the same time to stop it.when i burn one out i just buy two bulbs.luckily my other car uses the same bulb so i never buy bulbs for it.
Old Sep 30, 2006 | 04:02 PM
Xophertony's Avatar
Axle/Gears: n/a
ohhhh... my headlight suck anyway. thanks i'll get on that.
EDIT. there is actualy a tech article on the main page about how to re-condition your headlight system. i never thought to do al that. quite good reading. i think i am going to do all that as well.
Old Oct 1, 2006 | 03:24 PM
jdspool's Avatar
I went ahead and changed both headligths and all 8 rear bulbs -- no more "R Lamp" or "F Lamp" faults -- just "system okay" -- first time I've seen that since I bought the car. The rear sockets were all gunked up -- a good cleaning a fresh bulbs all around did the trick. No more chasing the illusive "sensors"!!!!
Old Oct 1, 2006 | 08:34 PM
rhomanski's Avatar
the gunk on the rear lamps was dielectric grease.you need to replace it to keep the sockets from corroding.
Old Oct 2, 2006 | 06:19 AM
jdspool's Avatar
Yep -- I shoulda included that -- new grease in all the sockets as well. Thanks! Maybe we've saved someone the headache I went through wondering where the sensors were -- when I shoulda just spent the hour and a half cleaning and changing bulbs. Works like a champ.
MantyZ28
Nov 8, 2015 06:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
383cam
Sep 9, 2015 06:01 AM
Ian Irvine
Sep 4, 2015 08:08 AM
andy74
Sep 3, 2015 08:41 AM
