Electric speedometer info
Old Sep 21, 2003 | 03:36 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Seems to be a big problem when ppl swap motors or trans and forget about the speedo. lol I've been dealing with it for to long. Seems there are only 4 speedo senders and only 1 of those is sopossed to work with these thirdgen cars. Found a web page that says it must send 2000ppm (pulses per minute) to be acurate. I have seen to different kinds of gears for this though. There is a plastic gear which turns the speedo sender and it reads it and there is also a metal one that is magnetic. I'm just going to try everyone I can find untill I get one that works lol. So far the metal geared magnetic one didnt work. 1-4mph phisically it read 1-120 and then shut th engine off over 120. Ok this must be the wrong one lol. Well I though I would post all my reasearch on this here and some pictures I'm taking incause it may be of use to anyone. This has been a problem for to long and now I'm diging to learn everything about these electric speedos that I can. Feel free to ask any questions on this and I'll help the best I can, or someone else whom might know more might see it. Here is the dirrectory where I'll keep all the pictures of this.
http://www.darkenedwolf.com/89%20Fir...20speedometer/
Old Sep 29, 2003 | 10:24 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
dakota digital makes a buffer box wich makes it possible to run any kind of speed sensor and also to compensate for diff rear gear.
it cost like 75 bucks.
factory 3rd gen is 2000 ppm, 4th gen is like 16000ppm
factory spedo is 4000 ppm
thanks
anthony
Old Sep 30, 2003 | 05:04 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
anthony
Do yo know what the 4th gen LS1 speedo is?
Old Sep 30, 2003 | 05:13 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
heres somthing i just made up one day... you might want the pic.
http://josh.swoca.net/board/mrdude/vss/
Old Sep 30, 2003 | 09:34 PM
@ZZKKER's Avatar
your link does not work.
i think it would be 4000 ppm. i used the dakota digital sgi-5 calibration box instructions for all these numbers. momar is using one on his t/a and i helped him set it up.
hope that helped.
here is a link to the page that the sgi-5 is on.
http://dakotadigital.com/Detail.cfm?...rtNumber=SGI-5
thanks
anthony
Old Sep 30, 2003 | 10:05 PM
Faded's Avatar
Car: '91 Firebird
Kinda off topic, but concerning the dakota box.
I want to install a 4th gen dash in my 3.1 Bird. Thing is though, I want to use a cluster from a V8 so that I can have the 160mph speedo. Now, to my knowledge the speedo and everything else will not have any problems, but the tach will not read the correct RPM's. Will this box be able to fix the Tach problem??
Old Sep 30, 2003 | 10:14 PM
@ZZKKER's Avatar
i think the 4th gen tach actually uses a 6 cyl signal, or was it 4 cyl. i dont remember for sure. but in any case dakota also makes a tach calibration unit
go here for it
http://dakotadigital.com/Detail.cfm?...rtNumber=SGI-8
thanks
anthony
Old Oct 1, 2003 | 12:20 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
heh, server prob... its been fixed and should be back up... save it to your HD just in case though.
Old Oct 8, 2003 | 09:32 PM
COOL! I fixed my problem! lol Check it out, here is the complication with an 89 Firebirds speedometer sender. They used two different kinds that year, one larger and one smaller, both sending different signals, more or less. The one that my car uses was only in production on the line for 4 freaking months! That makes it EXTREAMLY! hard to find at a junkyard lol. And in everyones books they show that its a magnetic type sensor and not a gear to electric sender. Mine is definally one of the gears but its an inche and 3\4ths in diameter or something like that. Very small sender to of been put on a firebird. All the others are two and a quarter. Unfortunally I lost the old trans and old speedo... well I ordered this rare discontinued part. They had one they shiped into from houston. Just one in that dealership.. which is pretty far from dallas. That was the closest one. I'm starting to think 5-10 more years no one will have that part lol. Well my hell of a problem is finally over. If you have an 89 Firebird be aware of that little speedo sender. I'll try to get the part number for that and post it incase anyone ever needs it. But this one is a bigger sender, just have to get an old sender housing off almost any 700R4 of around the same year with the electric speedo gear.
take it greezy.. or how ever you can get it
Elephantismo
Feb 13, 2019 12:51 AM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
TrevinE
Sep 14, 2015 03:20 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
