keep frying wires
Old Oct 7, 2003 | 08:16 AM
Berlinetta's Avatar
keep frying wires
I have a 91 RS 305 TBI that keeps frying a particular wire. The wire im talking about looks like it goes from the alternator, under the ac compressor, to the power distribution point next to the battery and radiator. the car kept frying it to the point that no wire was coming out of the fusible link. So i replaced the fusible link and it keeps frying the connection and I kept cutting and resplicing and now Im almost out of wire coming out of that fusible link. It usually takes it about 3 or 4 weeks to fry the connection. Im not sure what the deal is. I dont have any added electrical components except for another radiator fan and thats it. Stock radio has never been removed. Also, my car seems to eat starters. Every once in awhile, the car wont turnover but the dash will light up. All i get is a click. Usually if i wait around 15 minutes, it'll start. I replaced the battery cable and i still have this problem. Are the two related?
Old Oct 16, 2003 | 08:04 AM
Berlinetta's Avatar
help me please.
Old Oct 16, 2003 | 09:49 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
well, if it's not blowing the fusable link, chances are it's not exceeding its maximum current capacity.
That means that most likely, you need to find a better repair technique, or better yet, just replace the whole line.
Old Oct 18, 2003 | 06:30 PM
89BlueIROCZ28's Avatar
have you checked for a bad chassis ground?
Old Oct 19, 2003 | 08:37 PM
89_IROC_98U's Avatar
^ What he said...or maybe replacing the whole line (like Jim said) with a larger-gauge wire?
- 89_IROC
Old Oct 21, 2003 | 07:54 AM
Berlinetta's Avatar
thanks guys. All i gotta do now is try and find an RS in a junkyard.
Old Oct 21, 2003 | 08:40 AM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
Transmission: 700R4 B&M blue clutches
I wish I had problems that easy
Old Oct 21, 2003 | 09:26 AM
Jim85IROC's Avatar
You should be able to get that off any 88+ thirdgen. I don't think it's unique to the TBI motor. In either case, you can always make your own out of the proper gauge wire and an inline fuse.
Old Oct 21, 2003 | 09:54 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I had the same intermittent problem. I have an aftermarket air cleaner installed and it was pressing into the hot wire going into the coil thus intermittently shorting out to ground.
Check that!
BRoss99
Aug 10, 2025 05:08 PM
chazman
Aug 28, 2018 03:25 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
chazman
Aug 22, 2015 02:01 PM
