Prom Chip
Old Oct 14, 2003 | 06:52 PM
Impoeatr's Avatar
Prom Chip
hey guys i have a 1991 Z with a 305tpi auto...i was wonderin if any of you guys out there burn prom chips and how much you charge. the only thing i really need changed at the moment is a speed limiter delete. thanks.
Old Oct 14, 2003 | 08:33 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Post this in the DIY prom section. They know a LOT over there.
Old Oct 15, 2003 | 07:58 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
This isn't really the right forum for this question, but they will also rip you a new one if you go onto the PROM board and ask for somebody to burn you a chip.
Instead of locking this or moving it, I'm going to keep it open (for now) so that people can respond to your speed limiter issue. There is still some valuable tech content in regards to that.
I would suggest you read the PROM burning articles in the tech section of the website and spend some time reading up on the PROM board. Burning your own chips can be rather intimidating at first, but for simple changes like you are attempting, it's a no-brainer, and the equipment costs less than paying somebody to burn one for you.
But... you should do research first. TPI thirdgens don't use a speed limiter of any kind.
Old Oct 16, 2003 | 01:18 AM
Morley's Avatar
ahh, yes they did. If the car didn't come with speed rated tires from the factory they had a speed limiter in the chip (115 mph I think it was)
Unless you put speed rated tires on your car and can prove it to the person doing your chip, they shouldn't remove the limiter, it is there to keep you from killing yourself and others.
Old Oct 16, 2003 | 07:15 AM
Jim85IROC's Avatar
Well then, I guess I learned something new today. I've never heard that before, but I suppose it makes sense.
I guess I'm just used to being around the cars with the 16" wheels.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
dusterbd
Sep 29, 2015 08:40 AM
