cig lighter & accesory
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
My question is how do you wire your cig lighter to your accesory for your car. Im new to all this and can't get it working. Tired of battery dying b/c of damn radar detector.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
What, you can't unplug the radar detector of turn it off? I just thought of something- try elongating the wires for the lighter and splicing them into the YELLOW wire going into the radio, unless the detector will pull too much power and blow the fuse constantly. Someone correct me if I'm wrong!
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
let me get this straight? you have your radar detector pluged into the cig lighter & it keeps draining your battery???
i have my CB & scanner into my cig lighter & havent had any problems! granted i just replaced the battery but it was because the other battery was more then like 5 years old. both CB & scanner has been in the car for like 3-4 years!
are you sure that it is your radar detect. draining it & not something else??
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you can tap ignition only power off teh fuse box... without splicing into the radio stuff.
Engine: 2.7L V6
Axle/Gears: 4.41
I suggested that becuase it's less wire he has to use and it's easier to access, but he can do it either way I suppose...
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I've had my dectector wired to the fuse box for 10 years now and no problems. Even upgraded the detector last year and still no problems with battery dying.
Look elsewhere for the drain
ZZ3Astro
Aug 13, 2019 12:57 AM
