Swapping wiring on harness for H4 setup..
Old Oct 15, 2003 | 09:57 PM
PentastarTurbo's Avatar
From: Stockton California.. relocating to Modesto soon..
Id like to know how to swap out the wiring on my 86 camero so I can use the H4's that I had from my old 87 dodge charger (fwd)
how can I take the wiring terminals out of the connector to swap cavities?
thanks
Old Oct 16, 2003 | 07:11 PM
onebinky's Avatar
It would probably be alot easier just to cut the old plug off, and then solder the one for the H4's back in it's place. I think the tangs are a different design, and both should be a regular 2 wire setup making the cut/solder method much easier.
Something else to look into though, will the H4's fit in the factory housings? If they do, are they such a high wattage that they will melt the lenses or housings? If you are using the factory housings, I think it is glass lense and a cast housing, so you should be ok.
Matt
Old Oct 16, 2003 | 07:57 PM
Matt
the housings are metal/glass.. im upping the wattage one step above something like 80/90 or around there..
I hate to comprimise wiring and hack stuff.. Id like to have the option to go back to stock fairly quick if need be.. my car has 26K orignal and it was a garage baby..
Tank91RS
Aug 16, 2011 10:24 PM
Kevman
Car Audio
Apr 15, 2008 05:49 PM
LoudmouthSS
Nov 1, 2006 07:05 AM
85mcss
Aug 2, 2006 04:02 PM
cejohns
Sep 2, 2004 08:22 PM
