Shiftlight
Old Oct 17, 2003 | 04:01 AM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Shiftlight
I dont know if this is the right place for this but i didn't know where else to put it. If its in the wrong forum i apologize ahead of time.
I was driving around tonight and noticed on my stock gauges in my '86 T/A there's a shift light that comes on quit often. I dont know if it has something to do with switching from 2.77-3.73 gears and pulling higher RPMs and it just throws it on or what. I have never noticed this light comming on before even when going through the gears manualy (automatic, dont know why i do, but i do) and pulling higher RPMs. Any ideas?
Thanks!
Old Oct 17, 2003 | 07:15 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
just yank the bulb.
Old Oct 17, 2003 | 04:19 PM
So the shiflight is nothing to worry about? theres not a seperate bulb for that though is there? Theres i think a total of 9 back there for the gauges, and a bunch of openings to put more. If i put more back there it would make my gauges brighter right? Does anyone know where i can get the plastic piece to put the bulbs into so i can put more back there? I am redoing my gauges to blue, and there not all that bright.
Old Oct 17, 2003 | 06:49 PM
armac's Avatar
Car: 83 ta
shift light? a arrow pointing up? if it is my 84 had that and it is just telling you to upshift and is controlled by the ECM should not work in a auto though. very interesting.
Old Oct 17, 2003 | 06:56 PM
armac:
yep thats it. It comes on when im in drive doin about 40mph at about 2100RPM.
Old Oct 17, 2003 | 08:12 PM
armac's Avatar
Car: 83 ta
that is very strange. I will have to see if me 83 auto has a up shift light and put a bulb in it to see if it might work as well.
Old Oct 17, 2003 | 09:58 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
i tried putting a bulb in the shiftup socket of my dash on my 1990 pontiac firebird, v6 auto. the light did not work even if leaving the shifter in first and winding it up to 5k.
Old Oct 18, 2003 | 02:29 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
As far as I know, there shouldn't even BE a bulb in that socket, let alone should it light up, if the car originally was an auto, of course, or if the ECM was originally set up for the auto tranny.
Old Oct 19, 2003 | 05:59 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
I found that shift light thing today in my 87 firebird, i was laughing for a while that i had one, the bulb was pulled, and there was no cap for it i also saw another empty spot looked like
|\| dont know what its is but oh well guess i dont need it.
Old Oct 19, 2003 | 07:16 PM
armac's Avatar
Car: 83 ta
[/] would be the choke light if equiped
Old Oct 19, 2003 | 07:51 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Yes, if you have an auto transmission and fuel injection, the shift and [ / ] lights shouldn't be there, unless the car was converted at some point.
Old Oct 20, 2003 | 06:40 AM
TekViper's Avatar
Engine: 3.1L v6
the bulbs arent there but the actual socket and the lable for them are still in the dash.
Lbc5446
Jul 10, 2014 08:47 PM
vortech305
Feb 20, 2002 02:15 AM
