how to remove the distributor rotor?
Old Oct 21, 2003 | 08:55 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
so i bought a new cap and rotor, but what the hell, the damn rotor wont come off? is it supposed to pop right off?
i have an 89 camaro RS, 305 V8
Old Oct 22, 2003 | 09:03 AM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
Transmission: 700R4 B&M blue clutches
pull straight up and it should come right off ..
Old Oct 22, 2003 | 09:59 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
nope its not comming straight off !
Old Feb 17, 2011 | 06:19 PM
Alpinestar91's Avatar
Car: 1991 Camaro RS
Re: how to remove the distributor rotor?
I cant get mine off either?
Old Feb 17, 2011 | 10:47 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
it pulls straight off, they just get stuck on there from rust and grime.
Old Feb 17, 2011 | 11:16 PM
GerryCat09's Avatar
Car: 1986 Trans Am WS6/1991 Firebird
Engine: 305 TPI/305 TBI
Transmission: 700R4 in both
When they stick you can take a small pry bar and rest it on the bottom edge of the rotor, the lip so to speak, and gently pry up against a pivot point, I use the throttle cable bracket (TBI car), but to make sure you don't mess anything up, I emphasize, gently pry. They do stick, but it shouldn't take a lot of force to get it off, I just had the same issue a few days ago, took 5 minutes.
Old Feb 18, 2011 | 09:41 AM
Car: 1991 Camaro RS
Ok thanks for the advise it finally poped off
Old Jun 26, 2012 | 05:25 PM
Lichowid's Avatar
any good tips on where to pry? mine lifts off the manifold about half a inch and doesn't budge after that
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Derick15
Sep 17, 2016 05:28 PM
86IROC112
Aug 17, 2015 07:57 PM
3rdgenparts
Aug 8, 2015 07:09 PM
