Cruise Control Wiring Questions
Old Jun 18, 2012 | 04:44 PM
123pugsy's Avatar
I got a cruise control set up for my 350 TPI. This is going in my 76 Chevy pickup and I have the 700r4. Its a 1992 set up with the 7730 ECM.
I have a 2 pin harness that has a GRY/WHT and a BRN wire that comes from the brake switch from the N/C position. I'm wondering if that's supposed to go to a Pk/Ntrl switch or where?
Also, if the N/C postion is used up for the cruise control, how is the torque convertor lockup controlled when applying the brakes? Both wiring diagrams I have show these two things going thru the brake switch.
The other harness has a PNK/BLK and a BRN wire which I believe are 12 volts+ and the brown I believe is for the 2000PPM signal but not sure.
Thanks,
Pugsy
Attached Thumbnails Cruise Control Wiring Questions-img_4021-medium-.jpg   Cruise Control Wiring Questions-img_4014-medium-.jpg
Old Jun 19, 2012 | 09:57 AM
123pugsy's Avatar
Re: Cruise Control Wiring Questions
Some searching tells me there are two brake switches.
Can anyone verify this?
Thanks.
Old Jun 20, 2012 | 08:56 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Yea there are two switches that go on the brake pedal one is the actual brake light switch an the other is the cruise cut off switch
Old Jun 20, 2012 | 09:08 PM
123pugsy's Avatar
Thanks soarestransam.
There are indeed two brake switches.
One is a combo for the brake lights and electric cut off of the cruise control servo.
The other is a switch for torque convertor lockup and it also has a vacuum release for the cruise control built in to it. Must be a fail safe.
I need to modify my brake switch bracket to install the second switch and I'll be good to go.
I got a nut to fit the second switch I found in my box of wiring junk. I had to slit a castle nut and pry it open a tinch but she threads in nice. I'll tack this on to the plate extension.
Old Jun 21, 2012 | 10:41 AM
Engine: LR4 4.8
No problem bud maybe u can help me with my situation im also trying to get my cruise to work as well i have power going into the multi function switch i just dont have power going into the cruise module so would u think the multi function switch is bad ????
Old Jun 21, 2012 | 05:40 PM
123pugsy's Avatar
I found this drwg somewhere on this site and saved it.
You can do a continuity test using this and either confirm its the swich or something else.
I'd say its a good place to start.
Attached Thumbnails Cruise Control Wiring Questions-237654d1333410399-1984-cruise-control
Old Jun 22, 2012 | 11:28 AM
Engine: LR4 4.8
Yes this will help out alot my haynes manual only shows the whole wiring diagram for the cruise control. It doesnt show anything about the multi function switch just tells u how to remOve an install it
Old Jun 22, 2012 | 11:41 AM
123pugsy's Avatar
Let us know if it was the switch or not.
Old Jun 25, 2012 | 12:25 PM
Jeffrey Lemieux's Avatar
im new to this computer stuff so maybe im doing this wrong. I have a 1991 rs camaro with the 305tbi. she has 248211 miles on it and its all original, and they said the car was junkha. Any way i have an intermitent start and i cant figure it out. I have replaced the steering column, I have checked the vats system its not that ,the starter has been checked and is good, the starter relay hits, and all the power in the car comes on but the starter doesnt hit. Wait 20 min. and it starts right up,it could go 3 wks without a problem then it will act up solid for a week or so, and it has a brand new battery. Any ideas would be great.
Old Jun 26, 2012 | 04:30 AM
123pugsy's Avatar
Loose wire maybe?
Try starting a new thread so it will get more views.
This cruise control thread doesn't seem to be attracting much attention.
Old Jun 26, 2012 | 04:34 AM
123pugsy's Avatar
Can anyone tell me if its the large or small port on the servo that gets vacuum applied to it?
I had it hooked to the large port and man did my engine rev up nicely. I thought it was a Toyota for a second there until I got it shut down. Of coarse this was in Drive with the wheels off the ground. Scared the %$% out of me.
Old Jun 26, 2012 | 06:25 PM
123pugsy's Avatar
Small port gets vacuum and large hose is the vent that goes directly to the brake pedal.
So I got the hoses staightened out and she works fine.
I found the brake pedal slightly sagging and that was cutting off the electrical connection.
soarestransam, you may want to check that out. Lift up on the brake pedal and see if it works.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
