Fusible Links
Old Nov 4, 2003 | 10:49 PM
Clort's Avatar
Car: 1990 IROC-Z
Fusible Links
Does anyone know where the fuses in the lines of the delco bose rear speakers are?
Old Nov 5, 2003 | 08:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Clort,
According to my schematic for the delco bose system, there are no fuses for the rear speakers or for any of the speakers. There is the radio fuse located in the fuse block and the ARC fuse located in the convenience center behind the instrument panel to the right of the steering column (behind the ALDL). There is also a delco-bose amplifier relay located in the same area. Hope this helps you!!!!!!!!!!
The Trickster!!!!!!!!!!!!!
Old Nov 6, 2003 | 03:00 PM
Clort's Avatar
Car: 1990 IROC-Z
Do think I may have blown all my speakers? I haven't checked the fuses but are there any other possibilities?
Old Nov 6, 2003 | 05:13 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
I would say check the fuses. The one on your cd player, and the one on your fuse box. Then check your wiring. See if everything is wired up correctly. Let us know after youve done this.
Nate
Old Nov 6, 2003 | 06:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Clort,
You have e-mail. :lala: :l
Old Nov 6, 2003 | 10:14 PM
Clort's Avatar
Car: 1990 IROC-Z
I don't know if this helps you any better but the radio lights up and remembers what time it is. I only don't get any sound. Also do you know if they sell an adapter for the antenna or should i just unbend the metal piece at the end of it to make it straight? Thanks for all your help guys!
Old Nov 6, 2003 | 10:21 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
oooo, I had this exact same problem with the exact same symptoms!
It turned out it was a grounding problem with one of the rear speakers - the frame of the speaker was grounding against the chassis. The fix was to isolate the speaker from the chassis better.
Old Nov 6, 2003 | 10:36 PM
Clort's Avatar
Car: 1990 IROC-Z
I don't think it could be grounding on the chassis because I have the delco bose rear speakers which are in their own boxes in the trunk.
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
