Installing new Temp gauge
Old Nov 6, 2003 | 06:28 PM
lighthorseozzy1's Avatar
I want to install a new Temp gauge in my 1986 firebird..here we go>>>>What is the sequence, i go through to install this gauge..thats all i ask lol..what do i remove first and what is after that, i have to remove and what cautions do i go through doing this..i know someone has done this..so open up and let me know lol..thanks..ozzy:hail:
Old Nov 6, 2003 | 09:01 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Are you looking to replace the mechanicals only ?
You'll have to remove the cluster (search will net you those details if you are uncertain) Then remove the gauge assembly (pretty straightforward once cluster is out). If you're replacing the entire assy, you're done, replace old and reassemble. Gauge assy out, pop needle off and remove mechanics then replace. Needle on you can "calibrate" the needle using resistors betweent the sender wire and the block. 185ohm resistor should show 210°, 55ohm-260° (roughly, according to a few values I have).
After I repainted my needles, I calibrated my gauge by when the JET fan switch turned the fan on (200°). OEM gauges aren't terrible accurate so I wouldn't worry too much, close to accurate is enough to see if anything is seriously out of ordinary with engine operations unless you're really **** about monitoring engine vitals.
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
bamaboy0323
Aug 15, 2015 07:20 AM
fonzie85
Aug 13, 2015 11:50 AM
