Need help disengaging an alarm??????
Old Nov 27, 2003 | 04:22 PM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
I just bought an 89 Iroc-z and it has a vider alarm on it and i was hooking up my subs and once I was done the car wouldn't start and the alarm kept on going off and now my car won't start because it thinks that I am breaKing into it. Is there a way to hot wire the car so I can get it to an alarm place to get it disengaged or is there a way to can get aropund it. Please help!!!!????
Old Dec 2, 2003 | 05:17 AM
89redbird's Avatar
you don't got the little sender unit i don't know what to say i had the same problem with my push button start but i just had a crunky button i got it to work eventually Oh and the alarm never shuts up on mine
Old Dec 3, 2003 | 09:00 AM
Screamin'87GTA's Avatar
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
Easy fix
Are you sure its a vider not Viper?
"The little sender thingy" is called a vallet switch..
THe reason the car is doing this is because you probably disconnected the battery terminal to attach subs.
Go to www.dei.com Directed Electronics. They make the vider (Viper). to get the manual for the alarm..
If you want to bypass the "starter kill" Its pretty easy to do. Find the starter wire. There will be two brown wires splitting the starter wire, disconnect those and reattach the starter wire!
Constant 12V+ Red Ignition Switch Harness
(Starter) is (Yellow) in the (Ignition Switch Harness)
Ignition Pink Ignition Switch Harness
Accessory Orange Ignition Switch Harness
Tach White Coil
Brake Switch White Brake Switch
Trunk Pin White (-) Cargo Compartment Light
Parking Lights Brown Light Switch
Head Lamp Yellow Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger White (-) Driver's Pin Switch
Door Lock Light Blue Driver's Kick Panel
Door Unlock Black Positive Trigger
Horn Wire Black (-) Steering Column
*DISCLAMER*
This is on your own basis!
1992Z28!
Nov 19, 2015 07:33 AM
Papaginos
Sep 27, 2015 03:29 PM
bryanwood74
Sep 24, 2015 09:50 PM
Stauf
Aug 24, 2015 08:31 PM
ADAM NEAL
Car Audio
Sep 19, 2001 11:24 PM
