Need Help Alternator
Old Dec 13, 2003 | 10:56 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
I have an 86 Camaro Iroc-z 305 TPI The other day I noticed that My power steering Fluid was leaking on the alternator and wire and I noticed that The heavy wire that bolts on to the back of the alternator was first bulging then over heating then the plastic burnt off the copper. To the point it almost caught fire. Now my question to all you thirdgeners is the heavy wire that is connected to the back of the alternator where does it connect to I keep reading that it goes straight to the battery but it does not look like it goes directly to the battery Please help very confused
Old Dec 18, 2003 | 03:20 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
On my car, it does go straight to the battery. It runs beneath the throttle body, though that mess of everything, and connects directly to the positive terminal. I've been having issues with my alternator as well, so I'm VERY certain this is how it runs. I even pulled the damn thing off and tested it for continuity.
Old Dec 18, 2003 | 04:06 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
Actually, it should run to the starter on the battery terminal post. Yes...direct connection to the battery...and if you want to, you can run it directly to the battery.
Thats' just not how the factory did it!
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
