Foglights for a 88 TransAm
Old Dec 24, 2003 | 08:24 AM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Hello,
I finally figured out what one of the buttons does on my dash. It was right below my head lights and had a light bulb on the pic. I pressed it when the car was turned off and nothing happened...so I pressed it when the car was turned on and nothing happened. So I turned on the headlights and pressed the button and did a walk around and noticed my fog lights came on. Actually I should say fog light. The driver side foglight seems to be burnt. I was wondering, where can I go to replace that unit and how much is it going to run me. Thanks.
Old Dec 26, 2003 | 09:07 PM
bonz's Avatar
Car: 89 GTA
Any parts store will carry them. If I were you I would replace both at the same time so they have the same brightness and then dont have to worry about the other one.
Old Dec 26, 2003 | 09:23 PM
ThraxXx's Avatar
have you ever replaced them? If so..how much were they?
Old Dec 26, 2003 | 09:38 PM
Morley's Avatar
around eight bucks depending on the type of bulb they use.
Old Dec 28, 2003 | 05:26 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
one thing i have found, bulbs for my stock jeep foglights wre eight bux each, a set of new foglights was only twenty bux, look new! are new!, wired right up to old wiring harness. might want to go that route.gijoes will have em' same with AZ or pepe boys
Old Dec 28, 2003 | 06:16 PM
ThraxXx's Avatar
Man wish we had an autozone or pepboys up here in Canada. All I got is Canadian Tire and Wal-Mart. Well we got the local ***** shops (Quarter Mille Customs, Slicks Imports...). I would definately buy new foglights. Mine are pretty clear however I am sure they could be better, afterall...the car is an 88..its almost 16 years old and I am sure the previous owners never replaced them.
Also...Headlights on these TransAms...is it jus a bulb or do I have to replace the whole unit? My buddy drives an old TransAm, 2ndGeneration and he just buys the whole unit from walmart for $20 to replace his bulb...is that what I need to do when mine blow out?
Old Dec 28, 2003 | 07:55 PM
Morley's Avatar
Same as the second gen, sealed beam headlight.
Old Jan 5, 2004 | 10:55 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You might just need to clean the contact area where the bulb seats.
I just installed some fog lights on my friends 86 T/A with some aftermarket ones and he gave me the factory ones, which I wanted to put back onto my car since they look nicer than the aftermarket ones I have, stylewise.
There is a U shaped clip that holds the bulb in place and I guess it gets loose over time so I just rebent it and and cleaned up the contact area and one of them worked, the other needed a new bulb, cleaned the contact area, put the new bulb in and it worked too.
Btw, those factory fog lights are very expensive, $240 for the pair last time I checked.
I'd personally keep the factory ones and just replace the bulb if it's bad.
Old Jan 5, 2004 | 11:08 AM
ThraxXx's Avatar
ok ... I will just replace the bulb. I will be bringing the car into the local pontiac garage in the spring for a complete walk around and tune up. Replace every fluid, and bad sensors, dead bulbs, lube everything, oil change from whatever to full synthetic, engine flush, tranny flush, front end re-alignement...all the good stuff. I plan on getting them to replace the bulb at that time as well.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
evilstuie
Feb 28, 2016 03:33 PM
NZKnight
Oct 15, 2015 02:47 PM
pacoelrapido
Sep 11, 2015 02:41 PM
m00n420
Sep 11, 2015 02:39 PM
