How to get power from the ACC fuse
Old Dec 30, 2003 | 07:43 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I want to put in a CB so I can have a PA to play around with. I think that I have just about everything I need here. It says though I need to get 13.8v from the acc how do I do this. I see the fuse for it, but how to I plug it in?
Old Dec 30, 2003 | 09:38 PM
mb92camaro's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
You can go to any auto parts store. or your local radio sahck and buy a blade fuse tap that will allow you to put it over the metal fuse end. If you can tap off of an existing accessory wire, I would do that, but strip, and solder the wire for a better connection.
Old Dec 30, 2003 | 11:00 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You can use a male crimp connector and plug it into a cavity on the fuse block marked ACC.
Pete
Old Dec 31, 2003 | 01:20 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Where on the fuse block is this cavity? If I cannot find it I guess ill go with the first idea. Thanks.
I'm guessing I would need to take down the whole fuse block, if thats what I have to do is there anything special I have to do, or just unbolt it and pull it down?
Old Dec 31, 2003 | 07:24 AM
mb92camaro's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
If you have it on the block there will be like holes to plug in male flat blade connectors thye will be labeled bat, acc, lht.
Old Jan 1, 2004 | 03:26 PM
Here's a diagram of the fuse block, as it appears from the side the fuses are installed...
You can plug into the RADIO cavity to have power when your key is turned to either the RUN or ACC position; or plug into the IGN cavity to have power only when the key is turned to RUN.
These cavities will be toward the firewall.
Old Jan 2, 2004 | 07:02 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The connector they above are referring to is on the BACK of the fuse panel. Yes, you will have to unbolt it and pull it down. Here's a link to pics:
http://92b4crs.tripod.com/86wiring/dia-pics/11-0.jpg
Old Jan 2, 2004 | 10:46 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I used the fuse tap and it worked, but I like the plug idea alot better. Maybie ill pull it down tommorrow and wire it up right.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
