Electric door lock headaches
Old Jan 23, 2004 | 03:28 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
My power door locks will unlock fine, but when you try to lock the car, it seems like they're "struggling" to push the lock all the way. You have to press the button several times for it to actually "lock" the door. And they both do this exact same thing exactly. They seemed kinda weak when I got the car, and now I don't even bother using them. I checked the fuses, relay, and circuit breaker and they all seemed okay. I bypassed the relay and tried manually supplying power to the locks and it was the same story. I don't really know what the hell is going on with them. I wouldn't think BOTH actuators would go south at the same time?????
Old Jan 23, 2004 | 04:36 AM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
same thing with my car i just lock it by hand it sucks if you find out whats wrong let me know too please ............. thanks
Old Jan 23, 2004 | 08:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This condition seems to be a common problem with our cars. Clean with something like WD-40, then lube with white grease and you should be fine. Do the same with the window tracks and you'll note a definite improvement. Also, note the following link:
https://www.thirdgen.org/techbb2/sho...hreadid=124084
JamesC
Old Jan 25, 2004 | 01:12 PM
Wi$h's Avatar
Car: 91' Z28
Transmission: 700r-4
ya my 91' Z28 has a similar prob. the driver's side lock will go in but it pops right back out. unlocking both locks works fine and the passenger one locks fine. i talked to a friend who installs keyless entry systems, and he said it was the actuator. He said it would cost about $40 to buy a new one. i had the same problem your having when i had my 85' Blazer. had to sit and push the button a million times to get the lock to finally go. that was just some wiring which i never bothered to mess with.
Old Jan 25, 2004 | 01:27 PM
IROCZ28dan's Avatar
Car: 1987 IROC-Z
Its the actuator. Have it replaced.
Thats one of the first things I had done to my car when I bought it and noticed the locks stuck.
Old Jan 28, 2004 | 12:52 PM
MHarris's Avatar
Car: '92 Firebird w/T-Tops Black w/Tan Interior
Engine: 305 TBI
Transmission: 5 Speed
Before you go and buy a new actuator you might want to try a few tricks while you're inside the door panel.
Here are two threads I found very usefull.
One deals with pre '89 models having a loose ground screw on the lock relay which is right behind the driver side kick panel.
https://www.thirdgen.org/techbb2/sho...ght=lazy+locks
The other has instructions on how to take off your door panel and lube everything up. The article is actually for restoring your door panel but it has good instructions for taking it off.
https://www.thirdgen.org/newdesign/tech/doorpanel.shtml
Old Jan 30, 2004 | 08:00 PM
3gc's Avatar
3gc
Car: Z28
My locks were doing the same thing. What i did to cure it was remove the door panel and take the latch assembly out of the car and degrease it completely, then spray it liberally with white lithium grease. It has worked fine since.
BRoss99
Aug 10, 2025 05:08 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
billybob6110
Sep 23, 2015 01:30 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
