Power Windows
Old Feb 14, 2004 | 05:13 PM
Hollowmangt69's Avatar
Car: 1984 TransAm
Engine: Remanufactured V8 350
Transmission: Automatic
Power Windows
My windows would never go down but when I got some buttons I was able to, go figure but the only problem is now it wont go up. So now its freaking raining and ****. How can I get the window back up. Is the motor fried for the window? what can I do?
Old Feb 14, 2004 | 05:45 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
one thing to check is the connector under the dash I do beleive it's a big pink wire for the windows. perhaps the connector has become corroded.. Also what I would do is get that door panel off and power the motor directly and see if it'll go.. if not, it's the motor.. but if it works fine, then it's gotta be the wires.. another thing I would check is the circuit breaker. Power windows are not on a fuse like the rest of the system, because of the motors. perhaps you need to replace that.
Old Feb 14, 2004 | 06:23 PM
Car: 1984 TransAm
Where is the circuit breaker?
Old Feb 14, 2004 | 06:39 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is a 35 amp circuit breaker in the fuse block and is one of the two metal fuses.
Edited to correct wrong information.
Old Feb 14, 2004 | 06:50 PM
sr.bond's Avatar
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
have you tried to spray some electronics cleaner on the motor and some wd 40 on the rails of the glass?i had a similar glitch a while ago on my driver's side window and after cleaning and relubing everything the problem was solved.just my .02 :lala:
Old Feb 14, 2004 | 06:54 PM
Car: 1984 TransAm
so its necassarily in the fuse box correct?
Old Feb 14, 2004 | 07:37 PM
Car: 1984 TransAm
ok this is the deal. I went to try and make the window go up by splicing the wires and reconnecting them with another connecter that I pulled of a Pontiac Fiero. So I put it in and then when i went to turn the switch for the window to go up the part that was connected with the wires started to spark. I was like holy ****. So Now i'm still stuck with the same problem. I need help. I checked the wire from the window to the fuse box and it was fine. I still dont know what the problem is.
Old Feb 18, 2004 | 11:09 AM
Car: 1984 TransAm
It works. My windows now go down. It was the easiest thing to do. The power wire to the window motor was detached. It came off when the window first came down. It must have pulled the wire out. So thanks everybody on your advice. thanks.:yourock: :yourock: :yourock: :yourock:
Old Feb 18, 2004 | 11:43 AM
Jesus's F-Bird's Avatar
Car: 83 Pontiac Firebird S/E
Transmission: Borg Warner T5
Bwa ha ha ha, i am the evil spirt of power windows. Mine is broken too. Thats all
Old Feb 24, 2004 | 11:32 AM
Car: 1984 TransAm
Spirt?
Old Feb 27, 2004 | 11:20 AM
He ment spirit
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
