weirdest problem ever guaranteed
Old Feb 17, 2004 | 11:23 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
ok guys check this out...for the past 2-3 weeks now everytime i started up the car the seatbelt dummy light wouldn't come on. ok, no biggie, who needs it anyway? tonight when i was driving home with the parking lights and fog lights on, everytime i stepped on the brake the light came on. i did some research with the brake pedal (i.e. push on it a couple of times to make sure) sure enough something linked to the brake pedal is making it come on. everytime i pressed down on it i heard a clicking sound, like there's a switch or button it's hitting. i have no idea in the world why GM would place a switch for something like a seatbelt dummy light attached to the brake pedal. it just really makes no sense to me. if anyone can give me some info i'd come over and file your taxes or something lol
thanks guys,
-GTAman
Old Feb 17, 2004 | 11:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just curious here, when you were experimenting with the brakes, was the car in motion at the time or was it parked with the gear in park? Your switch for the seatbelts should be mounted somewhere near the seat. On my 89 Iroc, the seatbelt warning switch is mounted at the base of the seatbelt by the door and has a wire that runs along the sill up under the dash.
Old Feb 18, 2004 | 10:05 AM
GTAman's Avatar
trickster,
i tested the light out in both situations (parked and while in motion. while parked it was worse).
Old Feb 18, 2004 | 01:56 PM
GTAman's Avatar
ok, let me fine tune the problem: when i have the parking lights on and my foot is not on the brake, the seatbelt dummylight comes on. when apply and take away pressure from the pedal i hear a clicking sound like there's a button or switch there. ( i just paid closer attention today O_o ).
Old Feb 18, 2004 | 02:37 PM
Snake Oiler's Avatar
Car: 84 Z/97 Tacoma 4X4
Engine: 350 H.O Crate,slp 1 3/4,3"catback,Edelelbrock 1406,Edelbrock perfrormer Endurashine
Is the seatbelt fastened when this happens?
IIRC, there are 2 switches attached to the brakes, brake light SW,and one for the cruise control.
Old Feb 18, 2004 | 11:52 PM
GTAman's Avatar
yeah it is. infact just for the sake of arguement. i'm going to buckle both seats and see if it still does it. something tells me it will tho. The light still doesn't come one for that breif moment when i start the car. i'm totally lost on this.
Old Feb 19, 2004 | 12:02 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I don't know about your's GTAman, but my seatbelt warning light only comes on for a moment if I start the car without the seat belt buckled.
Old Feb 22, 2004 | 12:31 PM
noc_81's Avatar
Don't forget that the seat belts lock when the brake is applied, so more than likely there is some crossed wiring somewhere...
Old Feb 23, 2004 | 06:07 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
no, wires don't cross themselfs.
what circuitry is common to the seatbelt warning switch and the brake light switch?
usually the G-force is what locks the belts, unless GM put an electrical solenoid in the belts.
Old Feb 23, 2004 | 08:02 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Have you tried just pulling the 'audio alarm assy' out from the (in)convenience center ? (under the dash to the right of the steering column).
The alarm is tied to your park lamp, ign switch & gauges. It is only tied to the drivers side seatbelt. The switch opens (on the buckel) when the seatbelt is fastened. This breaks the circuit and should keep the light from comming on when you start the car (no unfastened sealtbelt signal.. no need to warn).
This box is also what lights up the dash light.
Since it is solid state, there's a good chance something inside has simply burnt up and is now not making it work properly.
As for the brakes... not a clue why that would be. The only thing I could think of is since the stop lamps are also powered off the 'stop haz' fuse, the burnt up audio alarm could be hypersensitive to the current draw when the brakes are applied. I'm not that good with that typ of electrical so I'm just guessing there.
That's all I've got... here's the little pest that's causing your problems...
Old Feb 23, 2004 | 08:12 PM
GTAman's Avatar
wow, thanks you guys. it happened to me again tonight. when i was about to apply the brake and put the car in gear, but before i did i turned the parking lights off and on again and it went away. i told you guys it was weird lol
Old Feb 25, 2004 | 02:36 PM
GTAman's Avatar
and the award goes to deadbird for his diagnosis! i say this because whenever you leave the key in the ignition and open the driver's door the buzzer goes off, right? well no when i do it, the buzzer doesn't go off. so it is the audio alarm.
so deadbird, can you give me more instructions on how to get the little bugger out.
Old Feb 25, 2004 | 05:37 PM
deadbird's Avatar
Engine: TPI 305/ v6
Sweet... and I haven't done my taxes yet either
Yes, the alarm should sound with the keys in and door open. It should also sound with no key and lights on (door open too maybe ? been a long time since I've had an alarm).
You should find the "convenience" center just under the dash, right behind the ALDL connector. You will have to take the trim panel off to access it (has 7mm or 9/32 hex screws holding it). There will be 2 tabs to press in and the center drops down... the a-alarm will be the one in front.
Here's a visual (I'm not really quite that white either lol)
Old Feb 25, 2004 | 08:12 PM
GTAman's Avatar
oh man, you even got me a pic. you are godly.
:hail: :hail: :hail: :hail:
P.S. does GM still make this part? because if it's possible, i'd like to repalce it so that everything works properly.
Old Feb 25, 2004 | 08:27 PM
deadbird's Avatar
Engine: TPI 305/ v6
I don't know about all that.
GM p/n is 10037041. You can check www.newgmparts.com www.gmpartsdirect.com or just www.parts.com to find a different dealer. Also, you could check the top page sponsers, they sell used f-fody parts. Also, www.tacreationsusa.com (I prefer them for used parts personally) or, just go to the local boneyard. Last option, you can just have mine (literally... well.. maybe $1-5 to ship it). I'm not putting it back in (I actually thought I threw it away before taking the pic of it lol).
Old Feb 25, 2004 | 08:50 PM
GTAman's Avatar
yeah i know man, if they can discontinue a throttle body they sure can discontinue something like that, but i'll give those stores a look for it. thanks for the P/N too.
Old Feb 28, 2004 | 07:42 PM
GTAman's Avatar
hmm, i doubt this has anything to do with the burnt out audible alarm, but my hazard lights don't work. i push the button in and the lights don't blink. the turn signal lights function no problem. i am having troubles with the turn signal, specifically when i want to make a left turn, i have to swiftly flick the lever down so it clicks and stays on. if i just push it down it won't stick. man, everything is going out.
Old Feb 28, 2004 | 09:39 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is a relay for the hazard lights on that convenience center fuse block near the audio alarm system. You might also have to replace the turn signal switch in the steering column. Good luck!!!!!!!!
Old Feb 29, 2004 | 09:27 AM
GTAman's Avatar
yeah, i was expecting to replace the turn signal anyways. it's all faded and i can't read what's written on there anymore. does anyone have a pick of this relay? i'm going to pull that audible alarm sucker out today so i might as well get both done in one shot.
Old Feb 29, 2004 | 12:12 PM
deadbird's Avatar
Engine: TPI 305/ v6
look above the blue 'circle' in the pic I posted.
Old Feb 29, 2004 | 11:02 PM
GTAman's Avatar
so it's that big sucker? deadbird strikes again! :hail:
i tried taking the audible alarm out today, but it wouldn't budge. i tried wiggling, wobbling, and straight out pulling it but it's still in there. is there something i'm not doing? i stopped yanking on it in fear i might break something.
Old Mar 4, 2004 | 11:47 AM
GTAman's Avatar
guys?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
