where did this go?
Old Feb 20, 2004 | 07:55 AM
i8a4re's Avatar
Car: 89 iroc-z
Engine: 350 tpi, 91 vette
where did this go?
I have an 89 iroc with a 700r4 and there is a couple wire harneses going to the tranny. problem is there is one not pluged in. anybody know what all the conectors are for on the tranny? I have reverse lights and speedo works.
Old Feb 20, 2004 | 10:42 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
What do the connectors look like & how many pins on them. Then maybe I can help
Old Feb 20, 2004 | 10:48 AM
MdFormula350's Avatar
mostly likely the torque converter lock up.
https://www.thirdgen.org/newdesign/t...ueswitch.shtml
Old Feb 20, 2004 | 11:12 AM
Car: 89 RS
That's exactly what I was thinking but just had to make sure
Old Feb 25, 2004 | 06:49 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
the computer controlls the lockup?
Old Feb 25, 2004 | 07:32 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Old Feb 25, 2004 | 09:10 PM
Kontrax's Avatar
Car: 86 Camaro
wonderful. i ditched my comp and still have the tranny...what to do. wonder how its going to run... aw hell i might have to convert to stick
Old Feb 25, 2004 | 09:39 PM
Kontrax's Avatar
Car: 86 Camaro
could i just get a non lockup converter and throw it in? would that work? this sucks, going to delay my whole project
Old Feb 26, 2004 | 04:58 AM
Car: 89 RS
You can get the converter to lockup even without the computer. There was an article in a magazine a while back that showed you how to do it if you are on a budget. I'll look for it later. If not then you can fork over some money & get a premade lockup harness that works without the ECM. There are a few companies that make this. Here is one. Go to FI Accessories & then look toward the bottom of the page
http://www.painlesswiring.com/catalogframe.htm
