Speakers making weird noise
Old Feb 23, 2004 | 08:16 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
My speakers just started making this wierd noise, its like a popping noise and a constant static in the backround, even if the music isnt playing. I recently canged my battery and my distributer cap and coil so I was wondering if that could be the problem. Please post some input, it sounds like crap.
Old Feb 23, 2004 | 09:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Do you have the internal coil? If you do, check the wiring on it for looseness or breaks.
Old Feb 25, 2004 | 09:47 AM
hitman's Avatar
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
buy a
noise filter.
It is applied to the power supply going into the radio. I have used them before with great results. I used to have that problem, but usually on an older car. If your lucky you can find them at Walmart or Autozone. Should be less than $10.
Old Feb 25, 2004 | 10:00 AM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
Couldn't that noise be coming from a bad ground too?
I had an issue with noise/static from the speakers due to bad ground.
Just a thought...
Old Feb 25, 2004 | 06:30 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
sounds like a bad ground. check your wires man
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
BlackBoulder
Aug 11, 2015 11:15 PM
BrianI
Aug 9, 2015 11:52 AM
