how do you change a tail light bulb?
Old Feb 29, 2004 | 01:40 PM
fuginasso532's Avatar
this may sound extremely stupid but...oh well.. here it goes. my rear right signal light is out. how do you take apart the fixture to replace the bulb. i tried to inspect it but it looks like the fixture is one bonded piece of plastic glued together. i didnt see any screws really. just a couple for the license plate lights. but i dont know how to access the corner lights. please help me on this issue. i may be out of place asking this question but i dunno where else to go. any help would be appreciated.
Old Feb 29, 2004 | 01:48 PM
MdFormula350's Avatar
open the hatch, pull the rear interior plastic piece that lines the whole rear area of the trunk well out. after that u will see most if not all of the plastic wings nuts to take the tail lights out.
Old Feb 29, 2004 | 01:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay fuginasso532,
here you go in several easy steps.
1. open hatch
2. remove two fasteners at ends of trim panel.
3. remove two screws near hatch catch.
4. remove trim panel
5. remove five wing nuts holding taillamp lens.
6. remove taillamp lens.
7. remove bulb from socket.
8. replace bulb in socket
9. replace taillamp lens
10. replace wing nuts
11. adjust taillamp lens for proper appearance before tightening the wing nuts.
12. install trim panel
13. install screws dear hatch catch.
14 install fasteners at ends of trim panel.
15. close hatch.
Done!!!!!!!!
Old Aug 10, 2012 | 12:36 PM
Brets_TA's Avatar
Car: 1984 Trans Am
Engine: 305 HO 4 Barrel
Re: how do you change a tail light bulb?
I figured out there is 10 butterfly screws, I kept hearing 6 there is 3 on both ends of the car and 4 in the middle, confused me. I assume I only need to unscrew the 6 end nuts and leave the middle 4 alone. Solved
Old Sep 29, 2012 | 12:25 PM
Beau27's Avatar
Car: 1991 Chevy Camaro Z28
Axle/Gears: 4.10
Are the bulbs really supposed to come out? Mine don't seem to want to twist or come straight out. I think they have been in there for so long that they have fused together or something. What is the exact method of removing these? Twist and pull, or just pull? Thanks.
The same goes for the front turn signal bulbs. I pulled on it and the glass came apart from the metal base.
Old Sep 29, 2012 | 12:45 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
You push the bulb in slightly and then turn it about 90 degrees like you are unscrewing it. It then pulls out of the socket. You should be able to get the old base out by grabbing the brass with a pair of needle nose pliers and following my directions.
EDIT: Be careful when putting a new bulb in. On the double filament bulbs, there are two locking pins that stick out of the side of the base. One sits deeper in the socket than the other. If you put it in backwards, it might go on in but the bulbs will burn the wrong brightness.
Old Nov 21, 2012 | 01:06 AM
Beau27's Avatar
Axle/Gears: 4.10
Thank you. I was able to get them out exactly as you said.
I am doing an LED conversion.
Old Apr 10, 2015 | 12:24 AM
BK2FUTR's Avatar
Car: 1986 Chevrolet Camaro
Engine: V6 2.8L
@beau27 how did your taillight conversion turn out? Im thinking of doing it myself as well!
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
