high beam switch
Old Mar 13, 2004 | 10:33 AM
pricem's Avatar
Car: 1991 firebird
Engine: 3.1
high beam switch
How do you change out hi-low beam switch on 1991 firebird with tilt steering wheel? Need detail help.
Old Mar 13, 2004 | 08:14 PM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
the lever is runs a rod that goes down the steering column. at the end of the rod is the switch your after. It is above the panel under the dash. Most times when this isn't working it is just out of adjustment. Hope this helps.
Old Mar 14, 2004 | 01:45 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...=high+beam+fix
this might help if the lever use to click but doesnt anymore.
GTAman
Mar 15, 2019 11:40 AM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
