Cluster lights gone
Old Mar 15, 2004 | 09:24 AM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Engine: (LO3) 305 TBI
Transmission: 4spd
Cluster lights gone
Ok one by one there goin out . First off my Volts and water temp meters went out. Then a couple days later my speedometer up to 30 went out and the next day after that my whole tach went out.
So im asking what the heck is goin on and how do I fix it. please help because I want to go to the strip and i cant see the tach w/o the dome light and i dont like racing with it on.
Old Mar 15, 2004 | 09:47 PM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Transmission: 4spd
please somebody has to know.
Old Mar 15, 2004 | 10:04 PM
3gc's Avatar
3gc
Car: Z28
Maybe they all are just dying at the same time? Have you pulled the cluster to see if they're brunt out? I think you have cluster that you need to replace the socket along with the bulb because they are soldered in, stock.
Old Mar 16, 2004 | 01:29 PM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Transmission: 4spd
So ok well Thats what i thought but I cant find a site. Do any of you happen to know a site
Old Mar 16, 2004 | 01:43 PM
3gc's Avatar
3gc
Car: Z28
A site for what? Removing the guage cluster to replace the bulbs? I've never removed one from a car with the later style guages so i couldn't help you there but you will most definately find how to do it with a search.
Old Mar 16, 2004 | 01:50 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'll have to agree with 3gc about them strangely dieing off at the same time. The lights still use the plastic, twist in sockets though so, you can still pull & replace the bulbs.
Also, when you do replace the bulbs, make sure the contact points are clean and rebend the socket contacts out a little to help assure good contact when you twist them back in.
Old Mar 16, 2004 | 10:01 PM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Transmission: 4spd
So if i took this to advance auo parts they could replace it.
Old Mar 16, 2004 | 11:06 PM
deadbird's Avatar
Engine: TPI 305/ v6
Jeff, you don't seem as though you're very familiar with cluster lighting (as most aren't since the bulbs seems to last forever and don't have to be taken out often).
If you were to pull your gauge cluster out, on the backside you will find multiple bulb/lamp sockets (black, green and grey are the 3 GM colors I've seen). They simple twist in to lock in place. GM has used these since at least 1970 (they were in my bud's 70 camaro cluster anyways). Anyways, these little sockets hold a standard 194 light bulb. These are the same ones in the side markers. The bulb (most of the time) simply slides in/out of the socket.
Here is a pic of one of the stubborn ones from my 91 cluster. It (the lamp) came out half way then the lower section of the glass broke. I had spare sockets so I just replaced it. Crappy pic from a crappy camera....
Old Mar 17, 2004 | 09:37 PM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Transmission: 4spd
Ok well yo nailed that on the head. About not knowing mucg about them and all. anyway i see what your saying and thanx for the help.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
fasteddi
Sep 10, 2015 09:32 AM
Jetmeck
Sep 4, 2015 12:29 AM
andy74
Sep 3, 2015 08:41 AM
tnrednneck
Aug 13, 2015 08:57 AM
