B4C Alt. ?? qwik one!!
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Did the B4C cars get a better altenator, and if so does anybody have the part #?? I tried searches and found nothing useful!! I just want something alittle better than the stock 105amp alt, and I want to be able to get it locally. Thanks
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
No idea. You'd probably want to upgrade the wires. Even the ones on my 94amp look a bit weedy, and are probably reducing the current capability somewhat. As it was an rpo option, I can't see it being anything else, but where you get one, I don't know. I think newer impalas have them too, but again I just don't know any more info.
Si.
Si.
You can get one from any starter/alternator rebuilding place. A good one is Keystone here in Toronto..they can rebuild your alternator while you wait and they have all the heavy duty parts like the HD regulators..etc
Car: 91Z
Steve, do you just tell them you need the Alt. from the police pakage?? I will call around and see what I can find, thanks man!!
Just say you want a heavy duty version rated at 140amp or similar. They'll know what to do and it isn't that expensive. You should upgrade the alternator wire that runs to the positive terminal as well.
Car: "02 z-28
Engine: LS-1
Originally posted by 91wtROH17's
Thanks for the help, anyone else able to shoot some info my way here??
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Here's a nice write up to installing one, complete with part numbers...http://sethirdgen.org/cs144.htm
Car: 91Z
Car: "02 z-28
Engine: LS-1
Used them both, the CS130D really wakes up the charging system. The 100 amp unit works better since it has a more aggressive charging curve at lower rpms. It solved all my low rpm issues. It's really worth doing for a TG.
Car: 91Z
Ya, I have to do something because at idle my charge is waayyy too low!! The rebuilt units they sell around here are only 100amp, that's what I have been using and they suck.
