engine fire
Old Mar 18, 2004 | 09:10 PM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
engine fire
Engine fire put me back a couple months with my car...and i have to replace all the wiring in the back of the engine....its a carb by the way so not that much wires. My question is should i just cut the burned wires off midway and continue with a new wire? like join em by those little yellow things that you crimp wires together with? what should i do
Old Mar 19, 2004 | 09:26 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Try to avoid using those crimp things as they are not very robust, especially in a car. If you can pull new wire through the whole length of each connection then thats is best, but otherwise if you can splice in new lengths of wire using a soldering iron, and some heatshrink sleaving for insulation, then that would be perfectly fine. Remember to get the proper grade of wire for the replacements.
Si. :lala:
Old Mar 19, 2004 | 12:13 PM
stomp1977's Avatar
Car: 1987 formula firebird
Engine: 305 lg4
My car did the same thing bured up the harness in the back where the ground conects to the motor and spread all the way forward on the battery side. I replaced all of the burnt wires, and now she runs, but i think i may have gotten one or two wires crossed. so it can be done its just a long carefull process. Oh yeah my car is an 87 lg4 4bbl. so they should be similar. good luck!!!!!!
Old Mar 22, 2004 | 07:19 PM
Engine: 350 carb
anyone else have any advice?????
Old Mar 22, 2004 | 10:23 PM
blk87ta's Avatar
Car: 86 Camaro Z28
Engine: LB9 305
Transmission: TCI 700R4
factory service manual, or perhaps a chiltons
timmy
Old Mar 23, 2004 | 06:08 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
My 87 GTA had a engine fire when I got it, I just started over and got a used harness for the tpi and one for the lights and now it runs great.
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 9, 2015 05:27 PM
