how to test an alternater
Old Mar 20, 2004 | 09:38 PM
Farfire70's Avatar
The subject says it all, I need to knwo if my alternater's going. What would be the signs that it's my alternator and how would I test it to be sure?
Old Mar 21, 2004 | 06:31 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Make sure the battery is good first. Most auto places can do a load test at no charge. Best way is with an inexpensive voltmeter, or for lack of that if the car has a guage look for this. With a voltmeter the voltage as measure across the battery when it's fully charged should be 12.6 volts. Start up the car and read across the battery terminals. Typical voltage should be at least 13.5-14.5. Lower than 13.5 usually indicates a charging problem. Everything associated with the charging system is inside the generator. With a guage with the accessories off it will typically read halfway between the 13 volt mark and the upper red zone after a cold start, then as the battery charges up it will settle down a little. If it below the 13 volt mark it usually indicates a defective gen.
Old Mar 22, 2004 | 03:13 PM
Hollowmangt69's Avatar
Car: 1984 TransAm
Engine: Remanufactured V8 350
Transmission: Automatic
Take it to schucks.
Old Mar 23, 2004 | 10:35 AM
Farfire70's Avatar
what's schucks?
Old Mar 23, 2004 | 10:53 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
on 1-3-03, I was having problems. I had it tested at autozone, and orlieys, they only have abilty to test volts.
I took it to advanced auto, they load/amp tested it, and it was bad.
I just recently having problems again. Stupid me went thru same routine again. Make sure they AMP/load test it, not just volts.
Shucks is an automotive parts store I belive in the north/west usa.
Old Mar 23, 2004 | 11:16 AM
Car: 1984 TransAm
Schucks is a automobile facility were you can buy anything you will need for your car. We have lots of them here in washington. Do you guys not have any over there?
Old Mar 23, 2004 | 12:44 PM
Farfire70's Avatar
not that i know of but I'll have to look around
Old Mar 23, 2004 | 01:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Schucks, kragen, advance auto and parts america are all the same company
they just have diffrent names in diffrent parts of the country.
Old Mar 23, 2004 | 03:32 PM
Car: 1984 TransAm
wow i didnt even know that. Well now i know. Thats cool.
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
