Weird electrical problem???
Old Mar 31, 2004 | 05:42 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
The other night I had a weird problem happen to me while driving.
Took the car out for a spin and everything was going as normal. Drove to my buddies place and I had to go over a rough patch of gravel road before I got to his place, came off the rough gravel and was on the pavement for about 20 seconds before I pulled into his driveway. Just as I was pulling into his driveway here is what went out on me...
- Park lights
- headlights
- interior lights
- dash lights
- radio
I never thought to check to see if the power locks and windows worked or not.
The car stayed running fine and the brake lights, fog lights, and signal lights stayed on. I shut the car off, started it back up but still all of that stuff was off
So I drove home (about 10 minutes of driving) and just before I pulled in my driveway everything came back on normal. all of the above listed things were working fine. I haven't driven it since because I want to find out where the problem is in case I have a potential for an electrical fire (that would suck!!!)
Can someone point me in the right place here to start looking?
I did a search and I think someone mentioned in an another post about a wire coming off the starter??? This wire feeds the accessory circuit or something like that.. it wasn't really clear....
Old Apr 3, 2004 | 09:45 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
fuse links coming off the starter. there are 3. you prob blew the accesories fuse. id start looking there
Cleotiz
Jan 6, 2018 08:56 PM
toones
Jan 6, 2016 06:00 PM
CORV3TT3
Aug 23, 2015 11:26 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
