Please help with Chip
Old Apr 1, 2004 | 03:48 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
Ok, i need to know how to convert that over to a v-8. Has anyone ever done it? Its out of a 90 Camaro, and i know someone has gotta have some brains. What resistor do i replace. I really dont feel like going out and spending half of my savings on a stupid chip. Thanks
Old Apr 2, 2004 | 06:45 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
come on, any one. Anyone have one froma v-8 sittin around that they can measuere the resistance on? Please..
Old Apr 3, 2004 | 07:13 PM
91blackgta's Avatar
what is that? where is it on the car? need more info
Old Apr 3, 2004 | 09:35 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
what are you trying to convert, and convert it to what?
Old Apr 4, 2004 | 03:28 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
That chip is located right in your actually gauage pod, on a 90-92 car. I am pretty sure it tells the tachometer what kind of engine it has. Right now, it is set up for a v-6. Usually, you just change a resistor. WEll, i dont have a v-8 one around, nor is there a v-8 car at a junk yard that i can find. So i just need someone to take some resistance readings or something.
Old Apr 4, 2004 | 04:21 PM
Kontrax's Avatar
Car: 86 Camaro
well if you want to change it just for the tach there is other options. ive seen the electronic boxes you can purchase and program that a lot of people use. there are mechanical ones too
Old Apr 4, 2004 | 05:00 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Well, i want to keep stock dash. And i figured there has got to be someone out there with a chip like i have...
Old Apr 4, 2004 | 06:13 PM
Kontrax's Avatar
Car: 86 Camaro
the box can be hidden under the dash. or are you talking about the computer running the dash acc? they are seperate from the computer if thats what you mean
Old Apr 4, 2004 | 08:30 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
That chip is what determines the v-6 from a v-8 IMO from what i can infer. That chip, now, is right below the tachometer inside the gauage pod. Anyone with a 90-92 Maro should have seen it. Now if i can get someone with one of them years with a v-8 to take some resistance tests, we would be able to help out the next person who gets in trouble.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
