gas gauge reads wrong all the time.
Old Apr 13, 2004 | 03:42 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
ok here is the deal bought this car a week ago and tryign to get all the bugs out of it any way the gas gauge never reads correct. when you have about half a tank it will go speratic and jump like crazy and then if you have a full tank it will read full but as you use gas it will drop but not the correct amount the lady i bought it from gave me an extra gauge but said that wasn;t the problem she also has had the wireing checked out from the gauge back and everything was fine yet they did not check the connections at the back end yet. could this be a short or is there a sending unit that could have gone bad?
Old Apr 13, 2004 | 05:36 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The gas gauge not going down the right amount from full is normal. On mine 3/4 of a tank is more like half.
What do you the gauge is sporatic when it gets to half? Does it move around while your driving or as soon as you start it up?
Old Apr 13, 2004 | 05:54 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
sounds like a bad sender to me.
Old Apr 13, 2004 | 06:13 PM
Car: 86 z28
yepp when i say sporatic i mean im driving down the road and its jumping around more then richard simons. i beleive its the sender due to the gauge has been replaced and still same problem also the wireing has been checked from the gauge to the rear altho it has'nt been checked at the actual sender.
Old Apr 13, 2004 | 09:38 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
also check the connection to the tank.. it could be corroded.. I thought I had a bad sending unit too.. man what a PITA to get at.. anyways I had tested mine and it was ok.. but there was a bad connection between there and the gauge..
Old Apr 13, 2004 | 10:50 PM
camaroguy8923's Avatar
Car: 89 camaro Rs
Engine: 305 V8
the same thing is happening in my car. i fill my tank all the way and i leave and i only have 3/4 of a tank. then 15 min later i have a tank that is way past "F"
Old Apr 14, 2004 | 12:40 AM
Car: 86 z28
yeah its harsh and the harsher fact of the matter is i drive 15 mins on a highway to get home everyday and to get to work and this being a new car i have no idea when i am low on gas or if im good so i constantly have to fill the tank it blows
Old Apr 14, 2004 | 03:23 AM
Zepher's Avatar
If in doubt, you use the trip odometer.
I usually put $10 of gas in the tank when it's near empty and reset the trip odometer. With gas at $1.90 gallon for 93, I am getting about 75miles/$10.
I have a working sending unit in my garage for sale, but it is for a carbed car, so there is no provision for a fuel pump.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
evilstuie
Jan 9, 2020 08:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
