override VATS
Old Apr 15, 2004 | 04:40 PM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
override VATS
i used to have a TBI car..now its a carb motor...so theres no computer...but the chip in the key is telling something not to start the car..anyone have any ideas on how to override this problem?
Old Apr 15, 2004 | 05:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There are two yellow wires that come off the ignition switch. They go to the starter enable relay under the left kick panel. The starter enable relay is controled by the VATS control module. There is a dark green wire that goes from the starter enable relay to pin "A3" of the Vats module. Disconnect the starter enable relay and but a fused jumper between pin "E" and pin "A" of the connector. Pin "A" is a dark green/white wire that goes to the Park/Neutral switch. This will bypass that portion of the VATS.
Old Apr 15, 2004 | 09:24 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is an update to my last post. I found this schematic for the ignition system on an 1985 camaro that should work for you.
Remove the starter enable relay connector, cut the yellow wire that goes to pin "E" where it splices into the yellow wire from pin "C". Next splice the yellow wire from pin "C" to the dark green/white wire at pin "A" which goes to the park/neutral switch.
Old Apr 17, 2004 | 10:39 AM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
will that also help with my gauges since they dont work? (unless the door is open)
Old Apr 17, 2004 | 10:41 AM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
alright the car starts up right away now...doing what ya said worked for starting (thanks) but my gauges still dont work..any idea?
Old Apr 17, 2004 | 10:55 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I will see what I can find but I believe that your instrument cluster is electronic.
Old Apr 17, 2004 | 02:27 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
You need to reattach all the sending units for the gauges to work. Do any of them work?? Speedo? What transmission are you using?
Old Apr 19, 2004 | 02:49 PM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
700r4 the gauges work butttttttttt only when the door is open...but the speedo doesnt work at all
Old Apr 28, 2004 | 04:19 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Sammy, I am chasing the EXACT same proble you are. My gauges will NOT work unless the door is open. When the door is closed the gauges kind of work, but only if the dimmer switch is set to the full down position. Its very odd.
Recently, I started to blow the gauge fuse pretty bad. In fact, if I put a 30amp fuse in there it will last for like 3 seconds then die.
And with my fun luck my multimeter doesn't measure anything other than milliamps. So I can't really attach the meter and find out anything.
Old Apr 30, 2004 | 12:51 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
sounds like a short/ground issue, but that doesn't exactly help you track it down.
Old Apr 30, 2004 | 09:17 AM
FruityOne's Avatar
Exactly. I already knew it was a short in the system. And I had a feeling where it would be. Trixter gave me some excellent help that just confirmed my suspicions.
Fixed the gauge fuse issue. Everythings back to the ol' problem again. I suspected a loose ground is causing the problem, I have yet to be able to track it down yet though.
Old May 1, 2004 | 10:58 AM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
i have yet to figure it out as well...if ya do let me know! its annoying!
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
