hatch motor wire connector
Old Apr 21, 2004 | 11:16 AM
thunderoad02's Avatar
I own a 87 camaro which had a broken hatch motor and i decided to just buy a whole new unit. I got one off ebay from an 88 Iroc. The problem is that one of my connectors on the new unit (the one that connects the unit to the car) is different from my old one and does not fit the connection to the car. My question is would it be possible to splice the wires and connect the old connector to the new unit and just use a wire nut and electrical tape. I dont want to ruin it if it does not work as i can resell it to somebody and hopefully not lose too much money. Any input would be appreciated. Thanks.
Old Apr 21, 2004 | 12:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Go to a junkyard and find an 88 or later car and take the connector from it. then take a small jewelers screwdriver or paper clip and remove the pins from the old connector and the new connector. Then insert your old wires into the new connector. No muss, no fuss, no splice and a neat looking job.
Old Apr 21, 2004 | 12:21 PM
thanks, but i already have both of the different connectors ( i still have the old hatch motor) so i should just be able to switch these right?
And for my own knowledge , splicing the wire and adding the connector would work right?
Old Apr 21, 2004 | 12:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, you could do that and yes you could cut the wire and splice it together. The way I mentioned just looks better IMHO.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
