Dome Light & Radio Wont work- Strange
Old Apr 23, 2004 | 11:51 PM
ajmcmahon's Avatar
Car: Pontiac Trans Am
Engine: Stock 305
went to go jump in my car tonight to come home- i shut my alarm off before i open the door and it gives me the 4 beeps ( meaning the alarm had gone off ) i had been gone all day and forgot to lock the door, stupid me.... I open the door, and the first thing i notice is the dome light didnt come on, no biggie, nothings missing in car, i figured the bulb died... then i start up the car and the radio doesnt work either......
what gives? perhaps a fuse blew ??? are the radio and dome light run on the same genral fuse? i couldnt check for blown fuses since its dark, and i wouldnt know where to start ....
any ideas?
Old Apr 24, 2004 | 11:21 AM
LO3Jeff's Avatar
Car: 1992 Camaro RS
Engine: (LO3) 305 TBI
Transmission: 4spd
I'm not sure but whenever you have a power faluire always check the fuses first. I know the dome is connected to the horn and power doorlocks. Its a 15 if that helps
Old Apr 24, 2004 | 12:06 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
the dome light and the constant power for the radio are the same fuse, plan on reseting your stations and clock. If its and after market stereo it most likely wont work without the constant power.
Old Apr 24, 2004 | 02:05 PM
ajmcmahon's Avatar
Engine: Stock 305
yeh, i gotta check all the fuses... i pulled out a little red one that said radio, and it looked fine.....
but so far my radio, dome, and horn doesnt work....
Old Apr 24, 2004 | 02:08 PM
Engine: hamsters
the radio fuse is the switched one, check the one that says horn or cigar?? Im not sure but yea the horn is also on the same fuse.
Old Apr 25, 2004 | 11:34 AM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
Id just pull out and check EVERY fuse. Cant take to long.
Old Apr 25, 2004 | 01:07 PM
5ltrbtr's Avatar
Car: 91' Z28 T-TOP
If your horn doesn't work either it is probably the 20 amp acc. fuse. Just wondering if you have or had anything pluged into your cig. lighter. if it goes bad and grounds it will blow the fuse everytime you put one in.
Old Apr 25, 2004 | 09:49 PM
ajmcmahon's Avatar
Engine: Stock 305
i checked evrey fuse, none of them are burnt, i even went as far as changing the fuses labled radio, and still nothing...
i never had anything plugged in to the cig lighter.
parked it at my girls house, 4 hours later go back in, and this all happens.
Old Apr 28, 2004 | 09:12 AM
Camaro_86's Avatar
Car: 86 camaro z28
Engine: 305 V8
Transmission: Automatic
I am having the exact smae problem as you. My dome light, Courtesy light, cigar lighter, radio, power locks all dont work. I've checked the fuses. 2 of the fuses are metal fuses and i cant tell if they're blown are not. If you find a solution to this PLEASE let me know and if i find out how to fix it ill let you know.
Old Apr 28, 2004 | 04:06 PM
ajmcmahon's Avatar
Engine: Stock 305
i just fixed it Camaro_86, and it turned out there was a short in my ciggarette lighter.
i found a blown fuse the " courtesy" something or another... a yellow 25 one, ( top right of the Red Radio one )... kept buying em and kept blowing evrey time i turned the car on....
i go to pick up my cig lighter and it is about 600 degress or so, ( melted the skin right off my fingers , ouch ) but anyway, i let it cool off, pry it out with some pliers, and disconnect the plug for the cig lighter, and vala- Fuses arent blowing anymore, and evreything works so far.
hope that helps...
Old Apr 28, 2004 | 04:07 PM
ajmcmahon's Avatar
Engine: Stock 305
also, the big metal fuses your talking about probably arent gonna fix that.. i was told when they " blow " , you'll hear a pop noise, and when they cool off they will continue working, but thats what i was just told.
Old Apr 29, 2004 | 02:49 PM
Camaro_86's Avatar
Car: 86 camaro z28
Engine: 305 V8
thnx
Old Apr 29, 2004 | 05:41 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Those 'metal fuses' are actually circuit breakers.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
Omega
Aug 10, 2015 12:46 PM
