Tach Has Mind Of Its Own
Old May 4, 2004 | 11:20 PM
82TA's Avatar
Car: 82 TA
Transmission: auto
Does anyone have any input on how to fix a tach from a 82 trans am? When it first starts up, it goes to 4500 at idle, then all of a sudden bounces back to "idle". Upon throttling up, the needle moves, but not in a accurate or precise manor. My car is 305H, no tach filter, the tach has a pretty brown spot on the printed circut board. I have read in here about people replacing some parts on that board, but the tachs that they were repairing were different than mine. I even tried another second hand tach from another 82 TA, it wanders too but in a different way. It will idle at 2500 and slowly move up as i throttle up. Is there anything else on the car to test, or do i just have two tachs that are out of calibration??
Old May 5, 2004 | 11:09 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Are you running an ignition box (MSD, etc.)?
Old May 8, 2004 | 09:08 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
You're talking about the tach.. tho do you mean the
engine is acting up ?
Does the idle follow what the tach indicates ?
$750 L98
Feb 1, 2025 02:25 PM
tmellott89
Oct 14, 2015 02:06 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Eric-86sc
Sep 28, 2015 11:37 AM
