No starter action when hot - tried everything!
Old May 10, 2004 | 09:13 PM
solstone's Avatar
Car: Black 91Z
Transmission: 700R4 (from factory T5)
Well, probably not everything...
It's the same problem posted here numerous times: when hot you turn the key to start the car and nothing happens - no click; nothing. Then the car cools down and it starts perfectly. It started out once in a blue moon and now it's almost every day. I've done some homework and tried the following:
New Starter
'Starter wrap' heat shield
New Battery
connections cleaned
tested - good alternator
recent ignition rebuild (condition exitsted prior)
The car is in great shape and otherwise runs flawlessly. Is the starter relay something i should focus on next? I've looked at a bunch of posts but haven't found anything that applies directly..
Old May 10, 2004 | 09:39 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Hmm, I had a similiar problem, I replaced it with a mini high torque starter and i havent had a problem since. They run around 200 bucks though. But i am very happy with mine. Draws very little power, and the car starts up within a second at all times.
Old May 10, 2004 | 09:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Just curious here, do you have a pellet in the key and does the security come on for 2 seconds and go out, stay on, or not come on at all. Also, have you looked at the fusible links.
Old May 11, 2004 | 12:06 PM
solstone's Avatar
Car: Black 91Z
I just bought the starter a few months ago and believe me the LAST thing I want to go through is putting another one on and shimming it up - let's hope it doesn't come to that!
Yes, I have the key chip and the security light comes on and then shuts off after 2 seconds.
Checked the fusable links? No, I haven't tried that - would they be susceptible to a heat-only problem?
Old May 11, 2004 | 01:38 PM
AmorgetRS's Avatar
Uhh, that sounds like solenoid heat soak. One thing you can try is the remote starter solenoid from a Ford.
https://www.thirdgen.org/newdesign/tech/solenoid.shtml
Try that
Old May 11, 2004 | 01:39 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If they are laying against a hot surface, they could be affected.
Old May 11, 2004 | 01:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try that
Seems like he already tried the starter heat wrap shield when he replaced the starter.
Old May 11, 2004 | 01:54 PM
AmorgetRS's Avatar
Yeah, and? He still has problems when the car is hot, sounds like he should totally rule out heat soak.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
gta892000
Aug 11, 2019 11:16 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
corey8084
Sep 17, 2015 02:56 PM
